Question about Sigma Computers & Internet
Sigma slot machine has RAMS WRONG wont clear wat is the repair tips
RAMS WRONG WONT CLEAR
compdoctor20
  • 172 Answers
SOURCE: no display
No, it is a motherboard processor socket problem, repairable only with a new motherboard. Can you give me motherboard details to compdoctor2005@btinternet.com
Posted on Dec 13, 2008
blulite111
  • 56 Answers
SOURCE: no display
sir usually in beeping its either you have a damage peripherals so it will not work and have you recently place new cards or hardware on your board? if you did or not please remove all hard ware and carefully place them back again and make sure that they will contact on their corresponding pins, then try plug it again, and make sure that all of your hard ware are in good condition and no damage even one. please try this solution please send us your feed back thank you and fixya..
Posted on Dec 20, 2008
  • 1891 Answers
SOURCE: The machine seems locked on 1 hr..wont clear or
unplug or turn off power . turn back try to program . if no luck / look for code on digital display . if no code replace the touch panel .. it has a stuck touch pad. ,, mm
Posted on Dec 07, 2009
SOURCE: Disk tray wont stay closed.
I am having the same problem with panasonic Karaoke player, it wont play anything cause the drawer wont stay closed!!! HELP!!!
Posted on May 15, 2010
  • 1566 Answers
SOURCE: I have a bizhub 350
The KMBS in the US are the only one authorized to clear the data on your NVRAM.
Have you tried this steps? This is to enter Service Mode.
Press the utility button -> Counter List -> Stop-00-Stop-0-1
Enter 8 zeros when it asks for numbers and then press enter or print.
Posted on May 25, 2010
Olympus tough 835 wont format memory cards eorrer message comes up
change memory card, if not OK clean the slot with cleaning spray, if not clear check the memory slot contacts inside.
Mar 19, 2016 | Olympus Cameras
My computsewing machine wont stop sewing ,what should i do
if turning the machine off and on does not clear it, taking the machine to be serviced would be a good idea, could be something wrong with the computer or have a short in it
Feb 26, 2016 | Euro-Pro Sewing Machines
Tipped mower wrong wont start backfires through muffler
if it back fires and pull cord gets outof your hand you have sheared fly wheel key
Aug 19, 2014 | Garden
Pc boots but no display. tried a new video card, still wont work. ram or motherboard?
Hi.
To start the troubleshooting,
Do one thing.
Clear the cmos.
To clear the cmos, remove the battery and the cmos jumper. You will see JCC on the mb and it is attached to pin 1&2
You can Short it to pin 2&3 or remove it completely.
Don't forget to remove the power-cord from the power supply while clearing the cmos. together with the cmos bat & jumper.
After that try a different ram and a different vga card.
At times dust get accumulated in the slot that prevent firm contact with the vga slot or the memory bank.
Use a clean paint-brush and blow away the dust on the card, the mem and also the slot in the mb.
Fix it firmly.
try this
If you need further assitance revert back
Good luck
Uttam
Feb 18, 2010 | Computers & Internet
Help
Change plug then use a small amount of starting fluid then kick it if it fires then dies your carb needs to be cleaned pull float bowl pull both small brass jet screws and clean they must be clear to see through when put up to a light reassemble and you should be good
Jan 31, 2010 | 2004 Yamaha YZ 125
My meile coffee machine cva620 is not froffing properly
check to see if your steam nozzle is clear unscrew tip and clean also run descaler thru to make sure steam tank is clear if still not ok steam tank thermostat may be faulty need to service machine hope this helps
Nov 05, 2009 | Coffee Makers & Espresso Machines
Hi there, i have a ic7-g motherboard i need assistance with a problem. when i switch it on, no image is shown on monitor? i have a green led on the motherboard when it is plugged in but when i switch it on...
remove battery on motherboad
remove rams clear the rams slot..
add the rams without battery
start computer if problem continuous replace ur rams....
Oct 13, 2009 | Abit IC7 Motherboard
No display
Dec 13, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Audi wont start
bypass the security by putting direct contact to a battery source to the starter relay it will start and clear its own code
Sep 03, 2008 | 1996 Audi A4
My motherboard cant boot-up
did you put the jumper back in correctly ??
if yes then
1.) unplug the system
2.) remove the cmos battery and the rams (memory)
3.) press and hold the power button for 10 seconds
4.) replace the battery and the rams
5.) plug it back in and turn it on
6.) if it boots, enter the cmos setup and load optimised defaults
Jul 14, 2008 | ECS Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Sigma Computers & Internet Experts
David Payne
David Payne
Are you a Sigma Computer and Internet Expert? Answer questions, earn points and help others
