Question about Meiko FV 40.2 Dishwasher
Service manual Meiko FV 40.2 - Meiko FV 40.2 Dishwasher
3 Suggested Answers
Kitcheneer
  • 11 Answers
SOURCE: dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Posted on May 10, 2008
  • 7 Answers
SOURCE: Err Code 210
What you need to do is check the resistance of the booster tank temperature probe. The error 210 means a short circuit in the booster temp probe. At room temperature, the resistence should read about 1k Ohms. If you are reading significantly lower than that, then you will need to replace your booster temperature sensor. You also want to check the 4 pin square molex connector on the I/O board on top. Make sure all connections are tight, secure, and that there are no "bridges" across the connections for the temp sensors.
Posted on Feb 20, 2009
I have a Meiko 40.2 undercounter dishwasher. When it begins the fill cycle, water for some reason is being supplied to both the booster tank and a small amount of water is being pushed through the ri
They are usual the same thing but it's probably the solenoid. It would be a double solenoid set up and they share components; coil, supply, etc. start there.
Nov 14, 2013 | Meiko FV 40.2 Dishwasher
Error 201 on the Meiko 40.2 undercounter. I am thinking that it is the float switch somewhere, the sump basin is filling up just fine. anybody have this problem?
Check that the water hose is correctly attached and is free of "kinks" or pinching. Also check that the water supply is turned on all of the way.
May 26, 2011 | Meiko FV 40.2 Dishwasher
What temperature does the Meiko FV40.2 operate at please?
1)for washing it will work at 60 deg 2)for final rinse at 85 deg.
Aug 09, 2010 | Meiko FV 40.2 Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
Keep getting error 202 just replaced the booster rinse motor and the heating elements meiko dishwasher
it's inlet water not sufficient. 1)check inlet water is entering in to machine. 2)may be inlet water solenoid defective. 3)check the rinse water pump is working.
Jun 24, 2009 | Meiko FV 40.2 Dishwasher
I need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
Mar 30, 2009 | Meiko DV 80.2 Dishwasher
Err Code 210
Feb 19, 2009 | Meiko FV 40.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Dishwasher fix
111
Floor pan Leakage
302
Feb 28, 2008 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
70 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Dennis Boxerman
ray gallant
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
