Re: I am trying to fit the washing machine door seal to...
Its a tricky one but the easiest way is tolubricate the inside of the flap with wash up liquid then starting at bottom feed it on bit by bit following round with other hand to stop it slipping off. Once on its easy to rotate into correct position.
You will need an extra pair of hands to help with the spring.
Hope this helps & thanks for using Fixya.
This is not easy and there is a real knack to it. You will find it easier to have a second person helping. One holds the spring in position at the top and the other at the bottom and roll the spring over your hands into the slot
Hello,you mean you have a door gasket. A good, step-by-step article on
this pesky concept of "panel-screw" gasket installation is found on
this handy page:
For all Free appliance repair videos visit our VIDEO
TUTORIALS
Disconnect all power to the machine first!!
1Locate the
outer clamp band securing the seal to the door rim on the washing machine and
examine it carefully for holes or tears. Many can be prised off with a
flat-bladed screwdriver they have a spring system holding them, but some have a
tensioning arrangement that has to be loosened.
2After
removing the outer
clamp band, locate the inner one securing the seal to the drum and
establish how this is secured. It may be necessary to loosen a clip, or you may
be able to prise the band off with a flat-bladed screwdriver. Some are like
very large Jubilee clips that you have to undo usually from the top.
3Once the
clamp bands have been removed, use both hands to pull the seal away from the
inner drum rim. Some machines have a water spout holes that will have to be lined
up. Others have a drain holes.
4Rubbing a
drop of washing up liquid into the groove on the door
seal/gasket that locates on the drum makes fitting the new seal easier.
5the new washing
machine door seal should be fitted by locating the drain holes at the bottom
of the seal first then push it on with both hands working opposite directions
towards the top. This is quite hard if you have never done it before.
6 refit the
inner band remembering this must be tensioned correctly for it to be water
tight.
7 now fit the
outer band and the test the machine for any leaks,
All washing machine spares featured in this article are
available at apart4u with more video
help in our tutorial
section.
Information provided is a guide only. aPart4u accepts no liability for any
problems occurring whilst attempting any advice shown. If in any doubt about
fixing your appliance, always contact a qualified repairer.
TUTORIALS
1Locate the
2After
removing the outer
3Once the
4Rubbing a
5the new washing
6 refit the
tight.
7 now fit the
section.
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal.
And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks.
appliance doctor
