Question about LG 42LG50 42 in. LCD HDTV
Pair sky+ remote to tv
I need to pair the sky+ remote to the new tv
  • Anonymous Jan 16, 2009
    cant program my remote
  • Anonymous Mar 31, 2014
    remote won't pair with the ROKU device
  • 27 Answers
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Code: 0206
4. Point your Sky remote control at your TV and press the vol + & vol - buttons. If this turns the volume up and down as you'd expect, then the tv should be set, press Select and the remote should work
Posted on Apr 08, 2009
2 Suggested Answers
  • 393 Answers
SOURCE: hi there i need code for sky remote to pair up to
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
Posted on Feb 28, 2010
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Hi there i need code for sky remote to pair up to samsung lcd tv model number LE40b652,have tried 0060 in the book but not working sky bloke said that there is a tv model number code
Feb 28, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
I need the code to pair the sky remote to the tv LG 42LG5010
ring sky up they will give you a code for your remote
shaun
Jan 10, 2009 | Televison & Video
Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
Jan 09, 2009 | Televison & Video
Pairing Sky+ Remote with Panasonic Viera remote
3. Press tv again
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
LG RZ17LZ40 remote control code
I have got the RZ17LZ40 tv from LG and just got my new Sky Plus remote Rev.8 to control the tv by using code 0206.
Sep 23, 2007 | Televison & Video
LG 42LG50 42 in. LCD HDTV Logo
1,483 people viewed this question
Computer Repairing
Computer Repairing
