Question about Singer 7426 Mechanical Sewing Machine
HOW TO ADJUST TIMING ON SINGER MODEL 636
NEEDLE HITS UNDER BOBBIN CASE
SOURCE: My Singer 2639 Bobbin case
Hi, I used to have the same problem. I pulled the whole bobin casing out, cleaned it oiled it. When I put it back in, I made sure the actual bobin was turing the right direction so the cotton didnt snag and pull casing up.
If you havent already tried this give it a go.Its amazing how much gunk gets in there.
Posted on Sep 03, 2008
  • 3422 Answers
SOURCE: Singer 1120 timing
h,
Timing" is the alignment of the needle at its lowest point and the hook on the bobbin case. The point of the hook must pass directly behind the "scarf" of the needle fo the interlocking loop of a "single needle lockstitch" machine to occur. Look closely at the needle. You will see the long groove along the front of it. This is where the thread rides as the needle goes up and down. If you look at the back of the needle you will see a flattened area just above the point. This is the "scarf"; it's flattened to permit the hook of the bobbin case to run right by it and catch the loop.
When a machine is out of "time", the hook is either too early or too late, OR to far away from the scarf to make the connection. You can send a machine out of time by hitting a pin, or breaking a needle "hard" (too fast through too many layers, etc.). You can usually identify a machine that is out of time by multiple skipped stitches at high speeds, or by stitching fast and then quickly putting it into reverse. Sometimes, you can scrape by if you rotate the insertion of your needle a little bit, this can help compensate for minor timing issues.
Posted on Sep 07, 2008
bargainbox
  • 1388 Answers
SOURCE: singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
Testimonial: "very helpful...thank you"
  • 136 Answers
SOURCE: same problem on a singer 4166
yes
Posted on Aug 29, 2009
  • 483 Answers
SOURCE: singer model 7442 needle hits plastic piece under
Perhaps you have bent the needle. Or perhaps you have shifted the bobbin somewhat while removing jammed fabric.
Posted on Dec 07, 2010
Singer touch & sew model 625 won't pickup the thread from the bobbin.
If you are threading the machine correctly, the perhaps the bobbin and needle timing may be off. If you open and look at bobbin case; there is a hook. As you make the needle go up and down you can see if it is aligned or not. You can adjust the timing arm (screw) that allows the needle to go up and down to adjust the timing. It is located behind the face plate (left side of your sewing machine that opens). This link may show you what you are looking for.
http://www.wikihow.com/Adjust-Sewing-Machine-Timing
Jul 03, 2017 | Singer Sewing Machines
Timing on a singer signature sewing machine
Search for sewing machine timing or take it for service.
PS--be sure to try it first with a brand new needle.
Jan 14, 2017 | Singer Sewing Machines
My sewing machine jammed the fabric into the bobbin case and now it won't sew the needle hits the plate under the bobbin case can I adjust this myself
Here are some videos that may help. If not, search the internet for thread jam.
How to Fix Thread Jam Sewing Machine
When Thread is Caught in Sewing Machine Sewing Lessons
https://www.youtube.com/watch?v=tDcBUR0PcyA
If you get it unjammed, be sure to install a new needle as the old one is probably damaged. If there are still issues, the machine's timing may be off and would need professional service.
Oct 23, 2015 | Singer 7470 Confidence Sewing Machine
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
I have a 5050c singer The bobbin case jump out and now the needle hits on the metal plate that is under the bobbin case. How do I fix this ?
I think that you have had the wrong size bobbin. It should be a class 66. Look in your manual, it should tell you. If, that is not it, call Singer at 1-800-4singer and ask if it sounds like the timing and if so where can you take it to get fixed. This is a nice machine, my friend, has one and it is worth getting fixed if you like it.
Jan 01, 2011 | Singer 5050 Mechanical Sewing Machine
I think the timing is off on my singer 7430 -- it keeps breaking needles and I can see where the needle hits the bottom of the bobbin casing when it is in the fully down position -- any quick fix?
Drop-in bobbin?
Refer to the maintenance section of the manual for cleaning.
Raise the needle to it's highest position and remove the bobbin and bobbin case.
Clean the shuttle and replace the bobbin case, noting the graphic in the instruction manual for aligning the case into the shuttle.
Turn the handwheel to see if the needle now clears the outer edge of the bobbin case.
Mar 29, 2010 | Singer 7430.CL Computerized Sewing Machine
Needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Oct 12, 2009 | Sewing Machines
Singer 7426 timing off
Aug 25, 2009 | Singer 7426 Mechanical Sewing Machine
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Singer 7426 Mechanical Sewing Machine Logo
41 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
