Whirlpool Generation 2000+ Model Number Needed
We need an inner main oven glass pane for a Whirlpool Generation 2000+, however, we don't have a model number. It's not anywhere any FAQs on the Internet say and we can't get to the back, because the oven is set into the wooden counter. Also, the customer said the oven was there when they moved in and they don't have a user guide with model number on either. We have pictures on our Facebook page, http://www.facebook.com/photo.php?fbid=249553788505161&set=pb.188484431278764.-2207520000.1354042050&type=3&theater. If anyone can point us in the right direction it'd be much appreciated! Rob Harris.
cj2176
  • 520 Answers
SOURCE: The Whirlpool Model LSQ9010KQ0 Type III fills and
That actually sounds about right but its a little cheep on the parts. Just make sure that this is the correct clutch for your machine.
Posted on Jun 12, 2009
award462
  • 395 Answers
SOURCE: I need English user guides / manuals for Whirlpool
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
SOURCE: Splendide 2000 Model Help Needed
I have the same problem with my WD802 "pre M". I have found this forum and it as helped me some. Here is one forum that might help you - http://applianceguru.com/forum2/17215.html - I think it's my control module, but I cannot find a test guide for my "pre M" WD802 module. I am Calling Splendide first thing tuesday to see if they have a tech manual for the "Pre M" models. Good luck with your WD802.
Posted on Jul 03, 2010
  • 2699 Answers
SOURCE: Frigidaire top load washer (FWS223RFS2) water
the tub seals are leaking,that washer is a dog anyway,you're better off getting a new washer,you need special tools to do this job
Posted on Oct 12, 2010
richroth
  • 9472 Answers
SOURCE: i have a washing machine
LSQ9549LG0 I think is your model number. Here is a link to a parts supplier if you need to order.
Happy Holidays! Richard
Posted on Dec 09, 2010
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
I need a new door inner glass for Panasonic NN-A772SBBPQ microwave/combination oven
Think about calling up the Sears 800-4MY-HOME line... the parts dept can look up your model with the LIS and have the part sent to your address and a Tech to install it for you if you don't know how, plus if you do pay for a tech repair for like $40 they do a clean and prevenative maitnence check on any other appliance you may have thats acting weird.
Mar 07, 2012 | Panasonic Microwave Ovens
Need pn for interior door glass oven pn RBS245PDS
Hello, Thank You for using FixYa. I will be helping you today.Part number 4449247 for inner door glass.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Whirlpool RBS245PDS Electric Single Oven
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Apr 22, 2011 | Frigidaire 30 in. Electric Gallery Pro...
Loose/broken seel on inner door glass of oven
Yes it is still avalible I looked it up and there is one in Texas here is the number to order. Genuine Parts & Accessories (800) 935-0062 please rate if this helped.
Aug 07, 2009 | Whirlpool GBS307PR Electric Single Oven
Can't remove oven door from Whirlpool model GR450LXH
the hinges problably require to be "locked" beforer removing from door frame, usually explains in hte manual "how to remve door". if needed, you can input your model number here, to download a copy
http://shared.whirlpoolcorp.com/product_literature/literatureSearchResults.cmd?siteCd=WHRCOM
Nov 26, 2008 | Kitchen Ranges
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Washing Machines Logo
Top Washing Machines Experts
