Question about Microwave Ovens
Thermador gcv36 gas cook top
This is an old drop in cabinet cook top gcv36 and a seperate venting unit that travels up an down as needed. vent motor is out side on the wall. can or do they still make this unit or a compatable one?
ScottSwan
  • 33 Answers
SOURCE: how does the vent work?
Under cabinet microwaves generally have two configurations for venting.
1) There is a vent cover plate on the top or rear (sometimes both) of the unit that can be removed and connected to a duct that vents up to the roof. If you do not have such a duct installed then that cover plate should be left on the unit so that it vents in configuration 2.
2) With the external venting ports sealed with the cover plate(s) the microwave simple draws air from the bottom (usually through 1 or 2 grease capture screens) and vents it out thought the front/top of the unit. This configuration isn't very useful as it just blows the air back into the kitchen. Many people don't both using the microwaves blower in this configuration.
Posted on Feb 16, 2008
rickzilla
  • 706 Answers
SOURCE: Microwave range hood install -- stud in middle of exhaust
You have a few options, First off, I am assuming that the stud you refer to is an outside wall. Assuming that is true, then you have a few options.... one of them is to cut thru the stud and run the vent out. Even if that stud is on a bearing wall ( meaning it is carrying a roof load above it) ... It is unlikely to pose a problem if that one stud has been compromised with it cut out, If that concerns you.. and you are handy, you can open that area of wall up from the inside and box the area that the vent will be located in with short pieces of 2x4 to the studs on either side of it... Another option is to vent the hood up thru the cabinet above and direct that out slightly offset to the stud in the wall..
One thing I have done is to cut the stud out and then to place a piece of 1/2" plywood in the area that the micro/hood will be located and attach that piece with drywall screws to the studs in the wall.. That piece of plywood will help support the stud you cut when you screw it to the adjacent studs and also act as a place to secure the hood mounting bracket on the wall. Granted, it shifts the hood out from the wall 1/2 " but then you have plenty of surface to secure the plate and don't have to worry about hitting a stud or using wall anchors.. I hope you understand my comments..If not...please respond to this and I will provide additional information to clarify this... Hope this helps !
Posted on Aug 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave MODel JVM1540DM1WW
I would double check the owner;s manual and installation instructions.
You can download GE owner's manuals and installation instructions here.
Posted on Nov 21, 2008
rickzilla
  • 706 Answers
SOURCE: Change the venting from internal to external?
Hello staufferbi,
It is possible to redirect the vent to the outsied but it is not a simple task. First off, you will need to remove the micro from the wall cavity and reposition the blower so that it vents out the top and not the front, then cut a hole in the cabinet above the micro ( lined up to accept the rectangular duct ) These tasks require fairly good carpenmtry skills and may not be suitable for the novice.. In any event, if you do attempt this.. then once you have the duct vented through the cabinet from the top of the microm you will need to attach that to wall vent feedthru. This normally means converting the rectangular duct to 4inch round and using an elbow. Needless to say, it can be done but is fairly involved. I did not mention anything about getting a 4 inch hole thru the outside wall and not thru a wall stud.,. Outside walls are typically bearing walls and although your roof won't cave in if you cut a hole thru a stud, it isn't advisable. Then you have to make sure it is sealed thru the wall cavity and properly cut into your siding. As I said before..it can be done but don't think it is a little job..
Good luck
Rick
Posted on Jan 09, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Posted on Jan 10, 2009
How do I change the front exhaust to top exhaust on a Kenmore microwave/hood
In order to change the venting on the microhood you need to uninstall the unit and at the top of the microwave is the blower unit. Remove the cover, flip the blower and you should then see the fins on the motor, reinstall the unit under the cabinet and your good to go. I hope this helps, good luck
Mar 15, 2015 | Kenmore Microwave Ovens
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
Our microwave, a Summit OTR 24 (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few...
Sounds like the electronics overheated. You'd have to pull it and examine the insides to see what has gone bad. It could be pretty much anything.
Can I install a GE Monogram II in a cabinet without using a trim kit if I install a couple of vent grills under cabinet? What could happen if I do this?
As long and you have cross ventilation (not just under the unit) you will be fine. If you only use bottom vents then the unit will be in a hottor than normal environment than designed for.
BUT most people don't use their units to cook with - so if you use yours like I use mine, it shouldn't affect it that much.
Sep 10, 2011 | Microwave Ovens
The exhaust system never has worked. Will not pull any air from the cooking stove under micro as it was supposed to.
Check the cabinet over the top of the microwave, the unit should be vented to the outside of your home, if not it was a venting model and just never connected to the vents.
Jun 14, 2010 | Maytag MMV4205 Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
I need to buy a new MBBS Thermador Microwave
I spent the better part of three days trying to find a microwave that will fit and it's hard because so many are on line only. Last night I successfully installed the 2.2 cu. ft. GE profile counter top unit with inverter technology. The unit is an exact match, the Thermador even fits in the GE box with the styrofoam! I installed the venting materials for the side and rear vents and the platform at the bottom. I put the clips and decorative molding on and it's perfect! I found it in stock at Lowe's for $198. I took me about 45 minutes total to install. If I can do it, anyone can - 48 year old mom with 5 kids!
Nov 27, 2008 | Thermador MBBS Microwave Oven
How to remove a sharp r 1481 over the counter microwave
If you are referring to an over your stove combination microwave/ vent system then they are typically secured thru the cabinet above them. Try opening the cabinet directly over the oven ( you may need a step ladder to see the mounting hardware) and look near the front of that cabinet for two screws on the bottom of that cabinet. These two screws go thru the cabinet and support the front of the microwave oven. You may also see the power cord for that mircrowave oven plugged into a receptacle inside that cabinet. Unplug that cord and then begin unscrewing the two screws. ( it's best if you have a helper work with you).. as you unscrew them, the front of the microwave should begin to drop down a bit. Once the screws are removed, you should be able to lift the back panel up a little bit to free the microwave of the wall mounting bracket. Once that is doen, you will be able to remove the microwave. I am assuming that your microwave does not have any vent pipe secured to it. If it does, then you will need to seperate that from the microwave vent on top ( assuming it is venting thru the top) .. These microwaves can be vented in any of 3 ways, thru the top, outthe back or configured to vent back into the room. In any case, you should see ductwork while removing this from the cabinet. Hope this helps you get the job done...
Sep 13, 2008 | Sharp Microwave Ovens
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Clean vent
The vent (also known as grill assembly in GE literature) comes off after removing the two screws at the top of the unit and gently sliding the entire assembly to the left about an inch. This will allow the vent to be cleaned of grease, hair, etc., as well as giving some access to the areas behind the vent.
Dec 21, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
