Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Tv is having wave problems and little blue specs
MY Mitsubishi DLP is experiencing problems, two different ones. 1. on all the channels, (and dvds) blue specs go in and out (like blow snow) as if the whole picture is not coming in correctly. They are tiny specs only about a 1/4 inch big probably, but theres probably a few dozensthat come in at a time, they come in and out over and over again while you watch tv. #2 problem is i see waves on the HD channels. Its like the picture has waves going up and down (horizontal lines) but this only happens on the HD channels. I had the cable company come out and change the boxes, wires, etc. but its obviously a TV problem since its happening on DVDs, and playstation also. anyone help??
  • beknal Dec 10, 2007
    I have the same problem as described in #2 (horizantal waves in the background while I'm on HD Channels) but when I play DVD I have clear picture.
    Any help is appreciated..
    Thanks
  • Harvis Kramer Dec 28, 2007
    seems to be the problem. I had a repair guy come out and tell me the same thing. Problem is the TV is only two years old so I feel like a shmo paying $900+ to get it repaired when I paid $5,000 just two years ago. I am hoping to get Mitsubishi to cover some of this cost. Thanks for the input.
  • 934 Answers
Distoritions like the symptoms you're describing are probably a defective light engine, Mitsubishi p/n#939p977020 If you go to price a new L/E they're approximately $975.00 and $300.00 of that is core that you get back when you return the defective one. This is NOT a replacement for the less than skilled either. Find a good reputable shop and have them do the job. If you get someone less than skilled you could end-up damaging the new L/E or something else like the color wheel. If you're not sure where to begin looking for a reputable shop I would suggest calling NESDA (National Electronic Service Dealer's Assn.) and asking them for a referral to one of their member shops in your area. Good Luck Bill
Posted on Jun 05, 2007
SOURCE:
Wd65737 Mitsubishi 65 in dlp tv, Does not go past blue welcome screen
Can you call up the settings menu? Check to see if the ANT-1, DVD, and other ports are properly activated. You may need to re-scan for channels and to activate the HDMI ports for your other devices. Regards.
Aug 13, 2015 | Mitsubishi WD65737 65" DLP TV
72 in mitsubishi tv has tiny white specs allover inside of entire screen can this be cleaned by me, I can hardly see picture is this picture tube or pixels. tv is not that old but located in not a very...
I suspect you have a DLP TV. The problem is the DLP chip. The mirrors are stuck and the DLP chip needs replacement. Mitsubishi does not make a 72" TV so that is why I suspect its a DLP type. It is not user repairable and there is no trick to get around it. You need a repair person or a new TV. (get a new TV trust me)
Mar 02, 2018 | Televison & Video
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
I have a mitsubishi 65"
its auto sensing optimal format from the input used u can try to go into your settings to force it full screen possibly with remote
Nov 17, 2010 | Mitsubishi WD-65738 DLP TV
Blue screen on WD-52525
Hi, Standby i'll sent you how.for a while
Apr 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
I have the same problem with my tv, my tv tech said mitsubishi knows of the problem and knows how to fix it, but it would cost me 700.00 plus his labor to take out the chassis and send it in to mitsubishi, plus I would be without a tv for up to a month. this is b.s.
Oct 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
sounds like dm module
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 DLP HDTV screen went bad
i have the same tv i got it for free from my work it was a return there's no picture or sound but the green light blinks on the timer light i took it to a tv repair place ive researched the problem alot most forums said it would be the dm module or the capacitors on it but this guy is sayn its not that and its not the lamp but it could be the color wheel or some balance thing he was bein an a hole about it i paid for a diagnostic and he said hes not gonna look at anymore cuz i dont sound interested in payn what he says MIGHT be the problem and i dont want to get screwed for a bunch of money any tips??? thank you
Aug 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
173 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
