Question about Genie Company Televison & Video
Genie intellicode gcg 350 ml instruction manual
3 Suggested Answers
blanchettohd
  • 143 Answers
SOURCE: What battery is needed fir a Genie Intellicode
The battery can be changed. There is a divet on the side of the unit. Insert a flat screw driver and pop it apart. There is a number on the battery. I believe it is 2032. The number on the battery cannot be switched although other ones look like it. Thanks BB
Posted on Sep 05, 2010
  • 3197 Answers
SOURCE: Need instructions to program Intellicode keypad
Go to these two websites for the info you want.
http://www.geniecompany.com/GenieCompany.aspx?cid=340
http://www.geniedoor.com/garage-door-opener-remote-programming
Posted on Oct 18, 2011
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
How to replace the battery on Genie ACSCTG Type 1
http://www.geniecompany.com/support_technical-faq.aspx
Call the number on this link to the company which it seems does not offer owner manuals online--if you have the manual it will have battery replacement instructions and type of battery used.
May 01, 2012 | Genie Company IntelliCode GICT390-1BL...
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
Need instructions to program Intellicode keypad series GCG and one button remote
Oct 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Someone guessed our code and numbers were outlined with a marker.... we need to change code but lost our manual.
Hi
There is a bunch of manuals for Genie intellicode systems on genie's website just click here to go there.
Hope this helps
Mar 07, 2011 | Genie Company IntelliCode GICT390-1BL...
Will not program
FIRST VERIFY THAT THE REMOTE IS COMPATABLE WITH YOUR DOOR OPENER (THEY CHANGED THE FREQUENCY A FEW YEARS BACK.
CHECK GENIE.COM
IF YOU HAVE THE CORRECT UNIT THE WEBSITE WILL GIVE YOU INSTRUCTIONS ON THE CORRECT METHOD TO PROGRAM.
NOTE IF YOU PUSH THE BUTTON ON THE REMOTE THE LITTLE LED ON THE POWERHEAD SHOULD FLICKER. IF NOT, YOU MAY HAVE A DEAD BATTERY OR THE WRONG REMOTE.
Jan 22, 2011 | Genie Company Genie Intellicode GITR-3...
How do you change your password.
Here is the link for the instructions to change the password look under Genie garage door opener manuals
Dec 25, 2010 | Genie GWKPDBL New Wireless Keypad with...
Need instructions on hjow to reprogram the remote adamsat6100@hotmail.com
Check the manual for your garage door opener (look online). There's a button on the back of the opener that you usually have to press, but the exact procedure will depend on your opener.
Aug 20, 2010 | Genie Company IntelliCode GICT390-1BL...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
I need to replace the battery on a Genie GICT-390 garage door opener. How do I open the case?
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Oct 24, 2009 | Genie Company IntelliCode GICT390-1BL...
Televison & Video Logo
237 people viewed this question
Top Genie Company Televison & Video Experts
Dan Apthorp
Leonard Manamela
Leonard Manamela
Are you a Genie Company Televison and Video Expert? Answer questions, earn points and help others
