Question about PANDIGITAL 8.0" Digital Photo Frame (PAN802)
Need to load pictures from panditigal frame to flash drive.
Lost pictures when computer crashed, but have them on a panditigal picture frame. Can I transfer the photos on the panditigal frame back to a flash drive or camera card?
  • Anonymous May 10, 2009
    I had to reformat and lost pictures on PC. I need to reload them from the Pandigital digital frame pan8002w02t, however, Windows xp says I need to format the removable disk. Is there a way around this problem?
    Scott
  • 423 Answers
Hi Doug, I'm sorry, but your pictures are stuck on the picture frame. There is no software on the unit to move them out.
Posted on Feb 21, 2009
  • Rob
    Rob Feb 21, 2009
    Ok, Excuse my recent solution above. There is a way to get the pictures off the picture frame. This is how you do it:
    Turn the picture frame power off. Plug in a usb mini cable to the frame and the other end to your new computer. Turn on the picture frame.
    Go to My Computer on your computer and you will see it as one of the drives. Double click on the drive and it you should see a folder with your pictures on it. Select them all (or the ones you want) and move them to your My Pictures folder.
    Wow that was easy. Sorry for the initial shotgun solution, but I did some research and found my mistake. Thanks for coming to FixYa, and I hope you'll forgive me and rate my response favorably.
    Rob
I want to play a flash drive with a movie with sound on it. I can't change from internal memory to usb flash drive. Can you help me?
I think I follow what your asking, so I'll do my best.
It reads that you want to play a movie you have on a flash drive through a digital picture frame.
Have you tried copying the flash drive to the internal storage and them playing the movie?
I think the biggest part of the problem is that the picture frames aren't capable of playing full movies, just slide shows. And any sound it has is on a separate section; not truly "linked" like a DVD or computer is. Picture frames are pretty much one trick ponies.
May 09, 2015 | PANDIGITAL 8.0" Digital Photo Frame...
My Grandma was given a Coby dp700 with pictures already on it for a gift. She would like more pictures. I can get different pictures from a usb flash drive to play as long as the flash drive is plugged...
Most digital frames come with a USB cable to hook the frame directly up to a computer. When you plug in the frame, a drive should show up in your "My Computer" section (for Windows) or on your desktop (for Mac). In most cases, you just need to drag and drop the photos onto the drive.
Mar 05, 2011 | Coby DP-772 Digital Picture Frame
Can't get frame to read files on USB flash drive
keep the drive you use to 2g or 4g max.for some reason a lot of the cheap frames cannot handle anything bigger.
Mar 29, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Downloading pictures from pc to photoframe
First install the application which you receive with the picture frame on your computer. Connect the frame with your computer by using the USB cable. Once you have connected the frame, you will be able to see an additional drive in "My Computer". Just copy the pictures from your computer and save them in that new folder.
In some software, which come with the digital frames will create a program by themselves after the installation. In these case, you need to open the program and then connect the photo frame to the computer. After connecting, you will see that the frame will synchronize with the computer and you will see that the program which you have already opened will show you the drive of the frame, where you can just transfer the pictures from your PC to the frame.
Jan 28, 2009 | Philips PhotoFrame -10 Digital Picture...
I have a compact flash card in my digital camera and I am not sure how to load specific photos onto the DBF-0802. I do not want to damage the card before I start. Abd also, how do I load images that I...
The digital frame only has 8mb of Internal memory, And if you’re using a high-resolution camera that means you’re only going to get a few pictures loaded into the internal memory. You would be a lot better off playing your pictures directly from the CompactFlash card. Once you place a flash card into the frame it automatically should go into a slide presentation mode and then you should do is hit play.As far as loading it from your computer you need to get a mini USB cord and connect that to the computer and the frame. Once the computer recognizes the frame you can do the transfer.
Oct 17, 2017 | Westinghouse DPF-0802 Digital Picture...
Virus on photo frame
I suggest you plug it in on your computer and use the existing anti virus program on your computer to clean it.
Dec 16, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Aug 04, 2008 | Kodak EasyShare SV811 (8858946) Digital...
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Coby DP-887 Digital Picture Frame: Unable to transfer pictures to internal memory
The Coby DP-887 does not have built in memory so one cannot "load" pictures onto it. It is a viewer in every sense of the word. If you load pictures on a flash drive or memoory stick and plug that into the Coby DP-887 then you'll be able to view pictures or video.
Dec 22, 2007 | Electronics - Others
PANDIGITAL 8.0" Digital Photo Frame (PAN802) Logo
290 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
