Can't get tv output trough dav dz500f
Tv has stopped outputting sound through the Sony system. Have changed all audio output jacks for new and tried with scart, but still no response. Although it still works when DVD and iPod is played the tv will not. The tv is a relatively new lg smart which did work originally.
3 Suggested Answers
  • 28 Answers
SOURCE: Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Posted on Feb 14, 2007
walesarumi
  • 6993 Answers
SOURCE: can't get HTS to play
below is feature of your sony HD KDL-32ex523.
Headphone/Analog Output: The TV's side-panel 3.5mm analog output can be used to connect a set of headphones or as an audio output to connect your home theater receiver or soundbar system. You can set the TV's analog output to Fixed or Variable. You can set the TV to automatically mute the built-in speakers when a set of headphones are connected.
Regarding the above, I would recommend you use a 3.5mm to RCA cord to get audio from the TV through your HTC. Below is a picture of what the 3.5mm to RCA cord looks like:
Now purchase this cord if you don't have one.
Connect the 3.5mm part to the headphone jack of your TV and the other RCA part to Aux of your HTC. By so doing, there should be sound from your TV coming through the HTC.
I hope the above is clear. If not, please let me know.
Regards.
Posted on Sep 15, 2011
How do I connect to TV using analogue cable ?
Some TVs have headphone output. It is 6.3mm jack or 3.5mm jack. Often located on the back of the TV if it is a LED ord LCD TV.
You probably need an audio cable that has jack in one end and two RCA konnectors in the other.
If it isn't sound you're looking for, but picture, and your TV only have SCART or component image input, you need equipment with SCART output or component output. Some SCART plugs do have separated audio and component outputs.
Apr 17, 2016 | JBL Cinema SB350 Home Cinema 2.1 Soundbar...
How do I connect my Sony soundbar ht-ct 260h to my blu ray player etc, I have no optical port or arc hdmi port,at the moment connected through the audio lead to soundbar & tv ?
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
Mar 30, 2015 | Sony HT-CT260H Soundbar and Wireless...
How do I connect my Coburn home theater to my Sony 52 inch projection TV I tried but get no sound
if the coburn has a scart interface u willl need a scart cable that terminates to rca the simple av vcr cable jack then ;ug the scart end to the theater and the rca to the tv front jack inputs n u ae ok alternatively get a hdmi cable that terminates to rca and connect the hdmi end to the theater and the rca to the dvi/ dvd/compoment input remember sony use icons not words for there accessories for audio input the icon is an in-arrow to a square box and output an out-arrow from a square box select tv. dvd or component av before u start
Jul 19, 2013 | Televison & Video
Headphone jack in tv has stopped working when putting speakers or headphones in is making a loud clicking sound. Is there anyway to connect speakers or headphones to the tv without using this jack? Have...
What type of TV, IE: Make and Model. If you have a SCART socket, then you can probably use the audio output connections on the SCART cable to connect to your stereo.
One thing to check is that your TV isn't muted! I know it sounds silly, but lots of people have inadvertently muted their TV's and not realized it.
Nov 14, 2017 | Electronics - Others
Hi, I am perplexed. I have a Sony KD-FS32170 model television. I just bought a Panasonic receiver to attach to my Sony along with four Bose speakers I already had. Unfortunately, I discovered there is no...
Hi
This tv should have one or two 21 pin scart connector;s on the back, using a scart to rca (phono) adaptor you should be able get audio out, and this can be connected to your sound sty. note the level will be fixed not dependant on the volume setting. Hope this will help regards Derrick
Aug 21, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Cannnot hear the music from video
you have not stated whether you want to hear the sound on TV or Stereo Receiver..
Here are 2 possible solution for both alternative..
1. thru TV
Your VCR has either 2x Audio (red and whitw ) and 1x Video output (yellow) RCA jacks or a SCART jack on the back side..
you need to connect all 3xRCA jacks to your TV's respective input.(or SCART ) than you will manage to see both video and hear the sound by selecting the VIDEO input on the TV .
2.thru RECEIVER
** you need to connect "Audio Output " RCA jacks of your VCR
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone )
** than just switch to respective mode on
RECEIVER corresponding your RCA connection...
There you go..VCR sound on the
Receiver..
*** pls remember you can connect VCR to either TV or Receiver to listen audio ,not both..the yellow RCA video output connection always goes to TV..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
I have an LG LCD TV (LG 37LG5000 37IN). I also have an older DVD Home Theatre System (SONY DAV-DZ100). It seems that the surround system works well with DVDs but I cannot get the sound to work with DIGITAL...
It works fine if you plug the surround system SCART lead into the AV2 input. I believe this is a 'smart' scart plug (same as SONY but it is not mentioned as in the literature). The AV1 is only good for inputs NOT outputs as well.
Oct 04, 2008 | Televison & Video
Help
you cannot get your tv to play surround sound through the speakers, but if your tv has either a scart 21 pin socket or an audio out, you can fit a scart to phono adapter and connect the phono plugs to the audio left right input on your sound system, likewise if you have audio left and right output(phono) on the tv, connect to audio in on your unit. You should have a choice of output channels on the system menu, similiar to DVD/video1/video2 or output 1 and 2 or auxilliary 1 and 2
Jun 04, 2007 | Audiovox DV1532 System
 Grubhead
Grubhead
