Question about Samsung HCN653W 65" Rear Projection Television
Red lines when watching DVD
Samsung HCN653W 65" Widescreen I am getting red wavy lines when watching DVD. I have tried everything I can think of and am getting pretty annoyed!!!!! I have changed component cables and even switched out DVD players with the same results. Is it the TV? or should I try a progressive scan DVD player? Watching tv does not have the lines, I only get this problem when watching movies via DVD.......please help!! thanks.
  • 934 Answers
Regardless of what inputs you use when the lines appear, that symptom suggests that the Proscan Module Samsung p/n#BP95-00140T is probably defective. That board is a plug and play replacement but there are no short-cuts to testing it to be certain that's the problem or the entire problem. That said, the top of the metal shield lifts off and the board can be pulled with no greater skill than a first year technician. The board is $184.25 plus shipping from Vance Baldwin - so if you're feeling lucky you could try this one yourself... Just be careful. If you have ANY questions drop me a note at premtech@willapabay.org and include the model number. Hope this helps Bill Good luck
Posted on Jun 05, 2007
My Samsung HCN653W 65-Inch Widescreen Projection HD-Ready TV has a 3d like picture when it has been on a hour it goes back to normal
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 05, 2011 | Samsung HCN653W 65" Rear Projection...
I have a samsung 65in hdtv rear projection and the colors dont line up it looks like triple vision what could it be
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Samsung HCN653W 65" Rear Projection...
It has kind of like blurry lines going accross the screen?
my tv also had wavy lines when running thru the cable jack or your standard RCA jacks. i used a S Video cable to hook up my cable and dvd player... with no lines. they are about ten bucks at walmart one of the componets on the signal board.. my dvi also works without any lines. just for the record ihave been fixing tv's in my garage now for about a year all these experts say they cant fix that with this model tv i'll try picking up a parts tv and changing what i think has gone bad inside this tv and let everyone know.. but i have told you a way to get around it and get back to watcing your tv without any of those annoying lines
Jan 25, 2010 | Samsung HCN653W 65" Rear Projection...
Shut down, no pic/no sound just the red timer light
You need to replace the lamp. you can do this yourself.
May 26, 2009 | Televison & Video
Samsung HCN653WX has wavy lines and red and blue ghosting
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2008 | Samsung HCN653W 65" Rear Projection...
Red Convergence will not line up
YES in this set there are two convergence ics called stks...on for red and one for blue...and green is controled by both.
Apr 28, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung hl-p6163w
ussally when u get coloerd outlined this idicates ether a convergence or a focuse problem.. the green convergence has become shifted. not lineing up with red and blue.. this also could indicate a green crt problem.. my advice is to get a tech to check it out.. it could be a simple adjustment or a whole new green crt
Nov 16, 2007 | Samsung HCN653W 65" Rear Projection...
Red/green drooping L top corner
i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65 in. lines.....lines.....help!
My first guess is it kind of sounds like a convergence board problem i know they had some service bulletins on them. hope that helps oh and convergence boards arent exactly cheap and will probably require some soldering
Mar 22, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
169 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
