Question about Refrigerators
Can anyone tell me of a site that I can access to download a manual to change a Westinghouse fridge doors from right to left opening
I need to be able to print out the manual. The one that came with the kit is faded and the print is very small
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Go to this forum and request the manual.
Posted on Nov 28, 2012
    President:
  • 1,082 Answers
bomark2002
  • 160 Answers
SOURCE: Freezer Icing Up
Try contacting the hotline again and ask them if the freezer has a frost sensor on it. If it does, the sensor is not kicking the thermostat to allow for the unit to defrost.
Posted on Oct 21, 2007
t0pc4t
  • 132 Answers
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Posted on Aug 15, 2008
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
  • 1075 Answers
SOURCE: Change the door opening from left to right. Can it be done?
on most refrigertators this is possable;take a look at the opposate side you should be able to see the holes already in place they might have little plastic covers in them remove and keep.if this is the case its not a big job compared to the kitchen job you done.simply remove the door and move the hinges to the oppisate side, the only thing that would consern me would be the handle position if there is one some doors open by pulling the door from the bottom if this is the case it might not be problem but check the hinges first if the opposite side has indeed holes in place i dont see a problem if you fitted a kitchen im sure a small matter of a handle will not stop you.hope this helps.adrian
Posted on Feb 16, 2009
I AM AFTER A MANUAL FOR MY WESTINGHOUSE 2 DOOR FROST FREE 517 LITRES REFRIDGERATOR MODEL RJ522V-R THANKS JULIE
Check the westinghouse web site. Many manufacturers publish user manuals for some products on their company websites..
Nov 13, 2015 | Westinghouse Refrigerators
I HAVE A WESTINGHOUSE FRIDGE. CAN ANYONE TELL ME THE BEST TEMPERATURE TO SET THE FRIDGE AND FREEZER TO
Probably no best, but they are adjustable to your own preferance. The MFG Owner's manual has a "factory" recommendation.
NO owner's manual? try manualslib.com
May 07, 2015 | Westinghouse Refrigerators
Our Westinghouse RS662V fridge is tripping the power. Has done it twice in the past 2 months. Any suggestions?
This solution is one possible answer if it applies to you. My fridge did the same and i thought the fridge was dead. The fridges freezer compartment's door was being left open and the freezer would thaw out and produce lots of water which would accumulate in the rear in a container which overflowed causing the fridge to trip the power. Closing the door and drying the rear container solved the problem. There are other causes too but if this applies to you it is worth giving it a try. Good Luck!
Jul 20, 2014 | Westinghouse WHITE Fridge Freezer Bottom...
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Refrigerator Door Reversal
you can switch most makes without extra hardware
Aug 28, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
