Question about Sharp Aquos Lc-42d64u 42in Lcd Tv lc42d64u
Optical audio sharp LCD no working with sound bar
Optical audio output from tv in LG sound bar not working. Sound bar works when plugged directly into devices but not the LCD.
4 Suggested Answers
jsinex2421
  • 62 Answers
SOURCE: No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
Posted on Jan 10, 2009
satavlad
  • 405 Answers
SOURCE: I have a Sharp 37d64u TV and the Optical out does
Unfortunatly, this model does not pass audio thru, optical output will work only with tuner.
Posted on Oct 23, 2009
dsacco86
  • 1077 Answers
SOURCE: No Digital Audio From Sharp LC-37D64U
Try changing the the Audio Setup in the Digital Setup Menu.
If you have your manual, go to pg 11 and pg 28 for Digital Audio Output. If you need a copy of your manual, here's the link.
http://www.sharpusa.com/products/TypeManuals/0,1083,127,00.html
Page 11 has info on the problem and page 28 to solve it.
If that doesn't work, I would try downloading the latest software to fix is problem. Page 28
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=LC-37D64U&s_func_disp_id=27&x=42&y=11
Posted on May 23, 2009
I have a LG TV 47LD650 that has picture but no sound out of tv speakers. If I connect an optical cable into the output and use a sound bar, will it still produce sound?
You have to go to setting and change the audio output to TV speakers for the TV speakers to work,, but, if you use a sound bar with optical connection...you have to set it also .. mine works the same way,,
Jun 19, 2017 | LG Televison & Video
How to fit anb3530a lg soundbar to toshiba tv
trade your TV or Sound bar to something that is compatible. IE Make it work, No optical port find a sound bar that works with RCA, Make certin you have RCA audio outputs on your tv, if you want the sound bar than New TV
Jul 28, 2014 | Toshiba Televison & Video
Hook up samsung sound bar to lg smart tv
easiest way would be to connect the optical audio output from the tv to the optical input on the soundbar. You may have to go into the tv's setup menu and enable the audio output jack
May 10, 2014 | Samsung HW-D450 Sound Bar
LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Samsung hw c-451 sound bar.I have it connected with optical audio out. I want to adjust volume of sound bar with DISH /LG remote and eliminate tv speakers
Dish doesn't appear to have a code for Samsung receivers but try the Sharp codes listed. Here's a link
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml#amp
Same thing for the LG remote
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
I recommend connecting your sound bar to your dish receiver as well as to the television. Play around with optical and RCA to see which one you prefer the sound of. The television isn't always the best center channel so you might find that you like this set up better with the dish receiver connected directly to the sound bar. Then you can shut of the television speakers. Some people turn the television speakers back on and leave the sound bar off for early morning breakfast news viewing. Not being sure which dish receiver you're using you might have to indicate to it how you wish to output your audio, or all outputs might be outputting at the same time all of the time.
Jan 27, 2011 | LG 50PK550 50 in. TV
Dec 15, 2008 | Sharp LC52SB55U LCD TV
Sharp Aquos Lc-42d64u 42in Lcd Tv lc42d64u Logo
560 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
