Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I purchased this unit on 02-07-07 and it worked fine until December of 2008. It turns on by itself, and flashes "Vegetables-Frozen" and then beeps and flashes "F3" at which point it freezes up and you have to unplug it. After plugging back up, it does the same thing.
  • Riaz_tahira Jan 10, 2009
    I was cleaning my GE microwave with cleaning spry and after that the control panel working and right now I have F3 on the screen
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Posted on Jan 10, 2009
SOURCE:
Mirowave won't stop running; fan runs, light is on only way to shut down is to unplug unit. Model:JVM1650WH05
Sounds like the control circuitry inside is bad,,,or the relay or switching device is stuck on...If the control circuit is bad then you will need someone qualified to repair the circuit...A word of caution...if you decide to try to fix the unit yourself I will tyell you that there are very high voltages inside that can KILL. Please do not service unless you are trained in electrical safety
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave Oven - JVM1650WH05 - Turntable does not work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 Microwave No Heat
heatman101
yuetywe
Jul 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
GE spacemaker model # JMV1640BB002
magnatron went bad need new one, cheaper to buy new unit
Feb 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
529 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
