Question about Sony ICF-C1IP White Powered Speaker System Docking Station for iPod (27242721739)
Sony IFC-c1ip mk2 no power when plugged in
When plugged into the mains electric the docking station has no power
2 Suggested Answers
SOURCE: Sony ICF-C1ip
hi, you resolv you problem of the icf-c1ip ?what is DC volts ?
Thanks ;)
Posted on Oct 22, 2008
How do I get music on my docking station through my iphone?
I would check to make sure you don't have a cable or headphones plugged into the Audio In jack. If not then I would suspect that you have a newer Ipod touch or classic that is not supported by this dock. Something changed a couple of models ago with ipods and the last two generations haven't been compatible on older devices meant to play through the dock connector. I have the same problem with an older Sony car stereo.
If you do have a newer Ipod then you can either get the patch cable to go from your headphone jack to the Audio in jack on the dock or you will need to get a newer dock.
https://docs.sony.com/release/ICFC1IP.pdf
Jun 05, 2014 | Sony ICF-C1IP (Black) Docking Station
Will a kensington universal docking station work with my sony vaio pcg-7d2l
Yes it should if you are running Windows XP, Vista, 7 or 8. You just connect to the unit using a spare USB port on your laptop and a plug-plug USB cable. It has it's own power so you'll need a mains socket. This means you can unplug your laptop and leave any devices charging on the docking station USBs. Your laptop should auto-instal the station. I believe there is a table/support available which combines with this unit. There a varying prices for this unit so look around.
Good Luck
Feb 27, 2014 | Kensington SD400V USB Docking Station with...
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Sony dock not working after iOS 6 update? Just says not an apple compatible product?? Any idea of an update or a fix on the way?
My wife had this problem with iPhone 4S after updating to ios6 on a Sony xdr-ds12ip docking station. Sound would play on iPhone off the docking station, but once it was docked no sound would come through the docking station speakers (docking station radio works fine, as did the iPhone before the iOS update). Fixed it by powering down both the iPhone and the docking station at the mains, gave it 2-3 minutes and then powered on the docking station and then the phone. Placed the iPhone in the docking station and voila the sound comes out of the speakers now.
Sep 29, 2012 | Audio Players & Recorders
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
Jul 07, 2011 | Sony ICF-C1IP (Black) Docking Station
How do I set the alarm?
I found a website to download the manual for the alarm clock for free
Aug 28, 2009 | Sony ICF-C1IP (Black) Docking Station
Sounddock power supply
Hi. To answer your question: The center line of the coaxial cable is ground. The inner metal side of the outer ring is the +18V. The outer metal side of the outer ring is the -18V. I will try to draw it below:
Sep 02, 2008 | Sony ICF-C1IP (Black) Docking Station
Sony ICF-C1ip
Thanks ;)
Aug 03, 2008 | Sony ICF-C1IP (Black) Docking Station
Sony ICF-C1IP White Powered Speaker System Docking Station for iPod (27242721739) Logo
21 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
