Question about Onkyo TX-SV525 Receiver
My Onkyo TX-SV525R clicks on & off when you hit the power button but will not turn on.
thaurfen
  • 623 Answers
SOURCE: Onkyo just shuts off...
check for blown fuses
Posted on Aug 15, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
  • 14 Answers
SOURCE: Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Posted on Mar 05, 2009
SOURCE: onkyo 870 relay problem?
le processeur du sircuit braker a trop chaufer... barbe-rousse-@hotmail.com
Posted on Jun 15, 2009
SOURCE: My Onkyo TX-SR500 receiver stays in standy/on mode.
It may be your amplifier protection circuitry is being activated and shutting down automatically. This is usually caused by a faulty output transistor in one or more of the channels. I recently repaired my Onkyo TX-SR500 which had this problem.
Using a multimeter on ohms check between C and E on each of the ten output transistors. I found Q6051 and Q6061 to be short cct on all pins. Once you have located the faulty channels check the adjacent components for open or short cct.
I replaced the following components,
Q6051 (2SD1047)
Q6061 (2SB817)
R6091 (2.2ohm fusible)
R6081 (2.2ohm fusible)
R6101 2x 0.22ohm 2W
Q6031 (2SD2061)
The amplifier now works perfectly, cost of the parts is about $15-$20.
If you don't feel confident doing this yourself just find a friend or tech who can do it for you.
Posted on Sep 03, 2009
My stand by light flashes on my onkyo tx-sr501
Check output transistors for short, change emitter resistors
Mar 30, 2014 | Onkyo TX-SR501 Receiver
Receiver will not turn on and is making a clicking sound TX-NR 609
This is the same problem i've had with my POS nr609. I will never buy Onkyo again.. Everyone warned me about the poor quality.. This thing worked for a year and a half, blew the amp., replaced and now another year and a half, f'd again. Save your time, buy a Denon or a Harmon Kardon. Better quality, same features.. Boat anchor here
May 15, 2012 | Onkyo TX-NR609
Tx-ds747 no display light,when powering on only stand by mode and the volume knob has light ,how to fix it.
Sounds like the "Pure Audio" mode is turned on. This mode is designed to use the amps power to dedicate to audio processing and sound quality. It turns off all front panel lights and video processing. Check you remote or thr front panel of the Onkyo for a "Pure Audio" button.
Nov 23, 2009 | Onkyo TX-DS747
I have an Onkyo TX-8511 Receiver. The unit has power because the standby light is on, but nothing happens when I press the power button or try and turn it own with the remote. I have Onkyo HTS907 that...
You have two devices that won't power on. Doesn't that suggest a source power problem? Did they ever or never work where you are now or anywhere else? Or did you just come back from overseas and forget to set them up for U.S. power?
And you're not daisy-chaining the two units together, are you? That's a no-no. There's a wattage limit to what can be connected to the convenience outlets. Power amps are not usually supported.
Try isolating the two units and shoot each bug separately. Plug them in somewhere else. Disconnect speakers and try again.
C'mon back with the results.
May 08, 2009 | Audio Players & Recorders
Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Nov 09, 2008 | Onkyo TX-SR605 Receiver
Onkyo 870 relay problem?
do you have speakers hooked up on B?
Jun 26, 2008 | Onkyo TX-DS777
TX-DS575 reciever
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
Jul 04, 2007 | Onkyo TX-DS575 Receiver
No Sound
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1, press Speaker A button.
4. You should see "CLEAR" on the display for a second and it will go on stand-by mode.
5. Turn on the unit and check if sound is back.
Hope this helps
Mar 30, 2007 | Onkyo TX-DS575 Receiver
Onkyo receiver
It sure dosent sound good!! The clicking sound you here are the protection relays to assist in protecting your speakers from blowing out. Your output devices are shorted it sounds like. Do not ever ever attemp to jump out those relays as it will burn out your speakers and possibly burn down your house!. Theres alot of current inthese amps for high power so if your not a tech and you think its worth it take the unit in to be looked at as there are no serviceable user parts inside these units . Sorry to have to tell ya this.. Good Luck
Jun 05, 2006 | Onkyo TX-DS575 Receiver
171 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
