Samsung Washing Machine WA80v3 not working properly
I brought it recently from local dealer in Oman,when I start the unit after loading the cloth and detergent the Water intake start automatically and immediately drained out....please advise the trouble shooting....
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Did the water start without you setting the cycle?
Posted on Nov 28, 2012
  • engjayant
    engjayant Nov 28, 2012
    When I use to start the machine after pressing Start/Pause Button and select the FUZZY instantly water start intake & draining out..
  • Richard Roth
    Richard Roth Nov 28, 2012
    Is the drain line above the tub level?
2 Suggested Answers
beltronic205
  • 1466 Answers
SOURCE: I have purchased SAMSUNG -
sounds like the drain pipe is too low resulting in Syphoning of water lift pipe above 24 inch floor level, this should cure...
Posted on Feb 01, 2011
What should I do to stop washer from putting grease on clothes?
Good Afternoon Bernard,
I understand the washer of your Frigidaire laundry center, model# GLEH1642F, is leaving grease in your clothes. I also see that you noticed the grease in the detergent cup. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine where the grease is coming from to be able to repair your appliance. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLEH1642F Front Load Stacked...
Sludge On white clothes
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 09, 2013 | Fisher and Paykel Washing Machines
Chalky wash
Try dissolving the detergent first, if it doesn't dissolve in the water by itself, change detergents.
May 20, 2013 | Sears Kenmore 3.6 cu. ft. Top-Load Washer,...
How do you clean **** buildup in a top load washer?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
9.2 Soiling
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
9.5 Black Marks on Clothes
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
9.6 Grey Marks on Clothes
this is a problem it is recommended that the machine be periodically filled with hot water, plus
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
9.8 Tangling
other. Do not load the machine by wrapping clothes around the agitator
Dec 03, 2012 | Fisher and Paykel Washing Machines
Fisher Paykell washer left black grease spots on some clothes
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
other. Do not load the machine by wrapping clothes around the agitator.
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
How do I clean gw711 lint filter
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
9.1 Creasing
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
9.2 Soiling
than soft water.
9.3
Linting
9.7 Dye Transfer
9.8 Tangling
Jul 09, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
After washing clothes, water stays in the detergent tray.
Best plan is probably to take the detergent tray right out of the machine, then take it to bits before washing it out with hot running water and a toothbrush.
The problem with these things is that the bit that blocks up is pretty well hidden until you dismantle the tray.
A.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
