Error 8 on bush washing machine hw60-1460d - Washing Machines
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Error code 8 bush washing
Hi.
Bush Error code 8 is overflow.
First try disconnecting power alone for five minutes. Trip the circuit breaker or unplug power cord.
If no luck, disconnect power and check the drain filter. On most models the drain filter is accessed removing the panel at the base of the appliance, in front at the right hand side. Keep a container ready to collect the water from drain line. Make sure no water is remaining in the machine before reconnecting power.
If the error comes back after re-connecting power and running a cycle, check the drain hose at the back. Make sure that the hose is not kinked and check height and setting of the hose. Height and settings must correspond to specifications on user/installation manual, or you get siphoning with water flowing back from drain hose. Siphoning triggers overflow error.
If the drain hose is OK and the above is not fixing the problem, then there is an internal fault. Usually a defective pressure switch or a leaking inlet valve can trigger overflow error. At this point the machine will need proper repair. Call the number listed on the user manual to verify warranty status and to get in touch with an authorized technician.
First try the complete troubleshooting above. Sometimes even a power reset can do the job.
Regards.
Ginko
Posted on Sep 12, 2011
  • 316 Answers
SOURCE: how to get rid of error 88 on my bush washing machine
Washing Machine Fault Codes ' Tips, Tricks & Recipes
this should help,,
Posted on Feb 21, 2012
My washer keeps saying err bush hw60_1460d
Oh boy I hope you're in the UK cuz that is a British unit here are the error code explanations
Error 1
Washing machine door lock has failed to operate or respond
The washing machine has detected an error with the door safety lock or interlock preventing operation.
Check door is closed and latched correctly
Check wiring
Check door lock
Error 2
Water drain time out or failure
The washing machine has failed to drain the water in a reasonable time, nominally in six minutes.
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
Error 3
Not drained in time allowed - washing machine fails to drain water
Error 4
Washing machine has detected problem with the wash heater
For this error code you need to check both the water heater or element and thermistor, the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
Check water heating element
Check heater for contunuity
Check thermistor or temperature sensor
Check the thermistor resistance
Check wiring to water heating element
Check connections to water heating element and temperature sensor
Error 5
Check water supply is on, clear and not frozen
Check the air chamber and pressure sensor hose for blockages
Check water inlet valve
Check wiring to water inlet valve
Check connections to water inlet valve
Check the main control PCB
Error 6
Motor heat protector error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit in relation to teh overheat protector within the motor itself.
Check motor connector block
Check motor carbon brushes where fitted
Check wiring
Check tacho connections
Check motor
Error 7
Motor error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit but, like other errors cannot pimpoint he exact location or nature of the fault.
Check wiring
Check motor
Error 8
Washing machine has detected an overfill situation
This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
Check for overfoaming or over soaping
Check the air chamber and the pressure switch hose
Check water level sensor
Check wiring to water pressure sensor
Check connections to water level sensor
Check main electronic controller
UNb
Washing machine has detected an out of balance situation
This error code is caused by an imbalanced of incorrect load in the washing machine
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3629-bush-washing-machine-error-codes
Mar 13, 2018 | Washing Machines
What does F;21 mean on my bosch exxel 7 machine
Bosch Washing Machine error code F21 .. Error message indicates a motor bushes replacement are required...or motor electrical fault.
Dec 30, 2016 | Bosch Washing Machines
Bush washing machine error code 8888 what does this mean
Error code Err 08 The start/pause light, program ready light and program end light blink. The motor has failed. Shut down your machine and unplug. Turn off the tap and contact the nearest authorized service agent immediately. http://electronicshelponline.blogspot.com/
Jul 14, 2016 | Washing Machines
What does it mean Bush HW601460D error 7 ?
I believe this is the fault when the motor bushes need to be changed. check the motor for black powder on / around it. this is a sure sign they are worn down.
Nov 07, 2013 | Washing Machines
My bush washing keeps making my fuse box trip
when I put my machine on to do a washing it blows my fuse box 8 mins into every washing cycle I select, It spins ,drains and rinses ok .So what can it be???????
Jan 22, 2013 | Washing Machines
What would stop a bush a126q washing machine draining, it just stops in the middle of a wash cycle?
hi i have a BUSH A126Q model W/M .Spin and Drain dosnt work. I clean the FILTER but same problem. Error code is Err 03. The start light & program ready light is blinking when M/C go to spin / Drain.
Its looks pump dont work //////
Please advise me what to do ???????????
Thanks
Mar 19, 2011 | Washing Machines
What does error 5 mean on the bush wm-1260tve washing machine?
Hi.
Error 5 means that there is a water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water pressure switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Sep 20, 2010 | Washing Machines
Washing Machines Logo
341 people viewed this question
Top Washing Machines Experts
