Question about LG DLE2512W Electric Dryer
LG DLE2101W Disassembly
My LG dryer turns on automatically whenever the door is shut. I imagine there is a relay somewhere, probably on the control board, that is stuck. I'd like to take a look, but am not sure how to go about disassembling the dryer.
    Top Expert:
  • LG Master
  • 9,472 Answers
Here is a list of dis-assembly videos to help you out.
Posted on Nov 28, 2012
Testimonial: "Very fast solution, thank you!"
  • Jeff Teel Nov 28, 2012
    Thanks very much for the quick help. I found exactly what I needed here:http://www.youtube.com/watch?v=AoI_NqzOZ...
  • Richard Roth
    Richard Roth Nov 28, 2012
    Thanks for using FixYa!
SOURCE: LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
This gives you what you need.
http://136.166.4.200/contents/Laundry/DLE2532/DLE2532_Service_Manual.pdf
Posted on Nov 11, 2009
MNTECH
  • 1543 Answers
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Posted on Dec 28, 2008
hunter19_46m
  • 7482 Answers
SOURCE: LG dryer won't shut off - gets stuck at 6 minutes
Your problem seems to be the timer switch is faulty.
Timer switches are normally non-repairable. You would need to replace the faulty switch
Posted on Oct 04, 2009
Macmarkus
  • 2605 Answers
SOURCE: LG dryer DLE2101W stacked on
Hello welcome to FixYa. The service of LG dryers is mostly from the front, with some at top, but you may have an easier time by taking it off the washer, its your call. How is the dryer mounted/secured to the washer ? Have you ruled out it isn't simply "bouncing" thus creating a tapping noise on the washer top ? If you have and the noise is from the front left, it is either a leveling leg, component of the drive assembly, or the blower/exhaust housing, you'll need to get inside to investigate. As far as tear-down/repairing most LG dryers is essentially the same. If you hang tight I will put together a generic LG step by step "how to" with pictures that will guide you through it. It is all from the front...virtually nothing is done from the back anymore. I'll wait for you reply to see if you're OK hanging tight since I won't have access to my PC until morning ( approx 8am mtn time ). Regards, Macmarkus :)
Posted on May 06, 2011
  • 127 Answers
SOURCE: How to change a belt
UNPLUG the dryer. Take the front kick panel off. Take the door off. Lift the top and rest it on something. Remove whatever is in front of the drum. Remove the drum. While you have everything apart check for worn pulleys and rollers. Place new belt around drum, and replace drum. Make sure belt is around the tension pulley. Replace everything in reverse order. Plug the dryer in and you should be ready to go.
Posted on Jun 07, 2011
Lg dle2101w is making a loug hum and rattle but works fine
the hum is usually a bad motor? perhaps u hear what u think is a hum? the rattle can be due to bad bearings, for example transmission spin bearings, tub thrust washer bearing, loose belt or worn belt.
Mar 08, 2015 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
Panasonic genius sensor 1250w 2.2cf
This may be a shorted relay on the control board, which can usually be economically repaired.
Or it may be a failing door switch or door switch mount. See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 10, 2013 | Microwave Ovens
Does a dryer have areset button
Generally speaking no. It might be the control board or the power supply or the control panel that is bad. You can take the top off and there should be a set of technician instructions that say what to test.
Jun 18, 2013 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
My dryer powers on, but nothing is happening
Could you please describe the problem you are having a little better?
Check the door switch to see if you hear a click when you push and release it.
Oct 19, 2012 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
Dle2101w
How to change a belt on a LG Dryer - DLE2101W
Jun 07, 2011 | LG Dryers
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Sharp Microwave oven controls do not work
You mean the turntable motor turns whenever the door is shut, even if you're not cooking?
If that's the case, then the problem would probably be a stuck relay (RY3) on the control circuit board, which we regularly repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If you have a different problem than I described, please reply back with details before you give us your rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 18, 2008 | Sharp R-1460 Microwave Oven
LG DLE2512W Electric Dryer Logo
565 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
