Question about Bissell 1693 PowerSteamer Upright Vacuum
Bissell powersteamer model 1693 not sucking up water
My bissell powersteamer model 1693 is not sucking up water from carpet. Hand held seems to have good suction. Everything was taken apart and cleaned, still not working.
  • meheather Apr 26, 2009
    my bissell 8920 works great but doesn't' **** very good...I have taken apart and cleaned but still not good suction.
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Posted on Mar 19, 2009
Ck. the plastic flapper under the Floor Nozzle Window and make sure it is completely closed when the Floor Cleaning/Tools Preheat Dial is in the Floor Cleaning setting. If this flapper is open or partially open, the suction vacuum will draw from the hand tool and not the floor.
Posted on Apr 25, 2010
  • 15,935 Answers
Put the handle all the way down to the floor, and closely inspect the pickup hoses now visible at the hinge. These models have a design flaw in the corregated pickup tube. One is for the floor, and one is for the wand. Chances are the floor tube has a big slice in it.
You can order the part online, however disassembly is tough! The tube is about $35.00
Good Luck!
Posted on Jan 10, 2009
Why does it have no suction?
The Bissell carpet cleaners and deep clean machines are a fantastic machine however they are prone to a couple of significant problems I find myself rebuilding a lot of these especially the 9200 series usually the biggest problem is they don't spray. in your case however I would think that you probably may have a blockage in the clean air duct for starters put the handle in the lower position to see if you have suction on the top of the machine also if you have an attachment for upholstery see if you're getting suction at the hose. Also check the red gaskets on both the cleaner tank and on the water tank to make sure that they are seated properly and they're not stuck in the machine they have to be attached to the tanks themselves. If everything seems to be ok then unfortunately it needs to be taken apart and the vacuum motor housing may have shifted or cracked o and therefore you're not getting the vacuum through the machine that you need to suck up the water. Good luck.
Feb 05, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell powersteamer model 1697 not extracting water
Check all suction connections. And make sure no debris in suction ports
Nov 01, 2013 | Bissell 1693 PowerSteamer Upright Vacuum
Bissell pro heat turbo will not **** up water,is squirting out water from sides of cleaner-any idea what may bo the solution to this problem?Thank You,Lisa
It may be a seal problem, or perhaps the water tank is not seated properly. make sure the seal is good by running your finger around it and feel for any bad spots, also a close visual inspection may show cracks or holes in the seal
Mar 17, 2011 | Bissell 1693 PowerSteamer Upright Vacuum
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can't get my bissel steam cleaner to sucktion
Check on board switch for tools only or vacuum, is switched to vacuum, as majority of vacuum suction power is diverted to hose/ hand held devices. See if vacuum hose has suction as well? The unit may be clogged with carpet fibresas well and the unit may have to be taken apart and cleaned thoroughly.
Apr 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I have a Bissell power steamer # 1693 and no directions need directions on how to use it
This is Vac's Etc. In Lake Charles.
E-mail Vacs.etc@live.com
Google search
How to use / Instructions for Bissell power steamer # 1693
Hope this helps....
Nov 04, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
My Bissell carpet cleaner model #1697-W will not dispense the cleaning solution and will not **** the water back up--also need to know how you get to the belt on the machine?
The drive belt for the pump is located under a cover on the front right side as you look for the front of the machine. Just lift it up and the belt will be obvious. If it is not sucking then make sure that the dirty water tank is empty and that all the filters are clean and the front of the machine is not clogged with fibres, dirt or hair. Also check pre and post motor filters and clean them if required. Then check the mix control is working OK to allow fluid to flow out of the machine and not switched off. Bissell's are simple machines.
Oct 06, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Motor running good but the water isn't coming out of either the bottom or the hand held tool
make sure your recovery tank is pushed down snug,somtimes it just need to prime itself,I had the same problem with my hand held tool, and that seemed to do the trick,after it pushed down,turn on power then wait about 10 seconds then turn on heater. I hoped this helped.
Oct 03, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
May 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 1693 PowerSteamer Upright Vacuum Logo
4,691 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
