Colour, contrast,sharpness,brightness specification for onida ky thunder for best picture quality......
  • 71 Answers
SOURCE: image set up
Yes.
Baclight 80%
Contrast 70%
Brightness 50%
Color 50%-60%
Tint 50%
Sharpness -6 to -8
OPC off
Posted on Dec 06, 2007
  • 36 Answers
SOURCE: picture settings
Looks as if the tv is at fault,stuck in reset mode,call the shop where you purchased it and let them know the fault,they will send an engineer out to sort the problem.
Posted on Apr 20, 2008
  • 5 Answers
SOURCE: Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Posted on Jul 15, 2008
  • 11 Answers
SOURCE: Picture settings
The settings is on the remote (menu)
Posted on Jul 31, 2008
SOURCE: DARK PICTURE ON ONIDA COLOUR TV
Check for the loose EHT line (along with the last anode cable),running between the EHT and the PCB of the CRT).It worked for the model 9999.
Posted on Jan 07, 2009
Onida ky thunder OXYGEN 29"
Check its 'S' correction setting. You have to enter its service mode to do this adjustment. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 13, 2013 | Televison & Video
I have a grundig GU19WDVD10 tv and the picture mode has got mixed up and the quality is not right. What numbers should the brightness, contast, colour etc be on? Thanks
In most cases, 75% contrast, 40 to 50% brightness and 35 to 45% color will be best. Adjust the picture sharpness control in between 10 and 25%
May 07, 2013 | Televison & Video
How to unlock the volume for onida ky thunder
how to unlock the hotel manger possword of onida oxygen thunder 1200
Apr 07, 2012 | Televison & Video
HOW CAN I GET GOOD PICTURE ,WHATS THE WAY OF SETTING
see the cable wires are connected properly,adjust brightness to 60% and contrast to 50 %,adjust sharpness to 0% and adjust the colour as per your choice.hope you can view a good quality picture.
Nov 10, 2010 | Televison & Video
What are the best picture settings for the 52" Sharp Aquos LCD
I'm happy with:
backlight +16
contrast +40
brightness +1
colour -13
tint 0
shaprness +2
although I found this setup but haven't tried it yet
backlight +5
contrast +24
brightness -7
colour +50 (review I found didn't say + or -. Try both
tint 0
sharpness -5
Len
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
FOGGY-HAZY PICTURE
The contrast setting should always be more than the brightness setting, it's purely common sense to have the black levels dark and the white levels light. I advise your brightness to be 40, and your contrast to be set to 60.
You shouldn't alter the hue, as most manufacturers would have spent significant time balancing this anyway, so set this to 50 and leave it alone.
The saturation shouldn't be altered too much, the best bet is to set this to 55 and let it be. Also, the colour temperature shouldn't be changed atall, so set this to the default setting and leave it alone.
As for the sharpness setting, this should definitely be set quite low. I advise setting the sharpness to 40, and the reason for this is most people assume that the higher the sharpness the better quality and detail, and they're completely wrong.
If you do what I said, you should end up with a crisp, smooth and colourful picture.
Nov 29, 2008 | Televison & Video
Onida Ky Thunder tv blackout
my onida ky thunder giving fault led blinking after plugin and after 5 second goes to stopped mode
May 11, 2008 | Televison & Video
JUST BOUGHT LG42LF66 FULL HD 1080P WOULD LIKE 2 KNOW BEST XD ENGINE SETTINGS AND COLOR,BRIGHTNESS,CONTRASR AND SHARPNESS SETTINGS THANKS J.SINGH
set my one like this:
picture mode=User1, contrast=60, Brightness=60, colour=30, sharpness=100, tint=standard setting.
colour temp.=cool, XD: contrast=off, colour=off, xdnr=high, mpeg nr=15.
Used gold plated scart for dvd & sky, picture looks pretty good, have not tried hd yet. Initial settings when first switched on were **** but with some tweaking have got good results.You probably have it set up pretty good now but just got mine & thought I would post this anyway.
Apr 23, 2008 | LG Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Televison & Video Logo
321 people viewed this question
Top Televison & Video Experts
Electro Med Services...
