Question about Craftsman Saws
Find Throat plates for Craftsman Table Saw Model 113.29903
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
protek480
  • 1714 Answers
SOURCE: Table Saw Craftsman 113.299410 Manual
Here ya go...
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0060111.pdf
Posted on Sep 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: Craftsman 10in Table Saw Model No. 315.218060 Dust bag
all the manual says is to insert the elbow onto the tube coming from motor and then install bag onto the elbow and for maximum performance empty the bag before it gets half full. On most table saws that I work on there is no fan or anything like that to force the dust away from unit, the best way is to run a shop vac and connect to the elbow for mazimum dust removal.
Posted on Mar 16, 2010
Testimonial: "Thanks, that's the way it is guess I was hoping That I was missing something. Thanks again."
agent91
  • 2100 Answers
SOURCE: Craftsman 10' table saw model # 137.248830 will not start
Reset button on the motor, push till it clicks. How about the breaker? What kind of switch is it? Is it plugged in? Check this stuff out. Hope it helps.
Posted on May 09, 2010
Need red plastic plate for table saw 055-6737-2 where do I find it
That is commonly called a throat plate and we need to know what the make and model of the saw is.
Sep 06, 2016 | Saws
Need to purchase delta 36-979 dado head table insert for 10' table saw
Use an appropriate pc of mdf that is same thickness of throat plate already installed. Use a router to flush trim to that throat plate. Now, insert and hold down with clamps and scrap panel. Raise Dado head ,while running, enough to do the job. This completes a zero clearance throat plate. No need to buy!
Dec 31, 2012 | Delta 36 979 10 Inch Left Tilt 1 1/2...
Table saw squeals and trips the reset. Is the motor shot?
It could be the motor bearings or the bearings on the spindle shaft. Also look to see if there is any debris in the throat plate area that might be slowing down the blade. causing an overload on the motor.
Sep 30, 2011 | Craftsman 10" Table Saw
Saw reset button keeps kicking after only a few minutes of use. Could the dust collection bag be creating a heat problem?
I would not think so, the reset is for thermal protection and I think that you have a problem with the motor stalling or under a heavy load. I would check to see how free the motor spins with being on. UNPLUG TOOL FIRST and turn blade by hand. Then to eliminate the dust bag remove it and just run the saw without cutting. Look into the throat plate area for a build up of debris that might be limiting movement.
Jul 23, 2011 | Craftsman 10" Table Saw
I just received my new saw 22116 however their is no dado insert which I use a lot. on other saw i have bought the insert was part of the saw. i have tried to find it in parts so far no luck. ken parkins
If you are unable to buy an accessory throat plate from Sears for your saw, you might like to look online at www.manageyourlife.com. You may be able to find accessories there that your local store doesn't stock.
I'm not familiar with your particular saw and it's throat plate, but you should know that many woodworkers make their own inserts using 1/2" plywood cut to fit the shape of the throat plate. You can trace your existing plate onto the form, then carefully cut it out and sand to fit. Insert small screws from beneath the plate to level it in position, level to the table top. Then cut a slot in the new throat plate by raising a small blade up through the new plate. Sometimes I use a skilsaw blade or dado blade to make the first cut. Do this only when it is safely held down with a long board clamped over top of it, while you raise the spinning blade up through the new throat plate to cut a slot or groove, as the case may be. If you can't lower the plate over the blade in its lowest position, you can either use a smaller diameter blade to cut through it, or rest the plate lightly against a blade lowered to its lowest position, then hold the plate in place safely with a long board or piece of plywood that rests lightly against it and holds just enough pressure that you cnn start your saw with the throat plate against the edge of the blade, then exert slight pressure downwards to fit the throat plate fully into the throat, cutting through it into the backing board, then you'll be able to raise the blade through the throat plate. This is a dangerous operation and should only be undertaken with safety equipment such as safety glasses or goggles in place, and alway keep your hands away from the moving blade and exerting force away from the moving blade. Exercise good judgement and caution and you should be able to plunge the new throat plate into position over the moving blade, using the backing board as a safety device/push stick.
If you are unsure about any of these instructions please don't hesitate to ask further, or refrain from taking any actions on your own, and in any event, proceed fully at your own risk.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 11, 2011 | Craftsman Professional Premium Hybrid...
I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Aug 02, 2010 | Craftsman 10" Table Saw
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Need dado throat insert for 113
why not just make your own out of 1/4" plywood
trace out the insert but don't cut a slot
install it on the saw with the blade all the way down
turn on the saw and raise the blade to cut out the insert
Dec 11, 2009 | Hardware & Accessories
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Saws Logo
70 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
