Question about Cyberhome CH-DVD 300 DVD Player
My cyber home not working
I have brought a cyber home 300 when i put the dvd inside its tellin me loaded then it says no disc and nothing what is wrong/
  • 2 more comments
  • poeticsoul Jan 10, 2009
    my cyber home 300 keeps tellin me there is no disc in the dvd drive first it says loading then no disc when there is a disc what to do
  • Afua Jan 19, 2009
    my cyberhome ch dvd 300 starts reading discs but then the message comes disc inside. It even happens with a CD/DVD cleaning disc.
  • pravin6381 Jan 22, 2009
    i too cant says loading..but wont play...
    i converted the movies into 8.vob format..but they too wont play..
    which format will play in this model and how to convert into compatible format?
  • Anonymous Jan 22, 2009
    cyberhome dvr 1200 says "no disc" after trying to read the disc but it won't play dvd movies or dvr+ or dvr-. Why not? took the cover off and cleaned the lens eye--- it was clean!?!
The draw does not open,why?
Posted on Jan 15, 2009
Cyber Home dvd player model CH-DVD 320 displays loading and never plays movie
Check the 5V power supply output. If its less than 4V it will cause this problem. Replace 5V power supply filter capacitors.
Mar 25, 2010 | Cyberhome CH-DVD 300 DVD Player
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
Fickle Players: Some DVD's play and others do not.
Most likely cheaply made DVD players.Try the DVD in another player other than the ones you have.If it happens's the disk.
May 31, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd says 'bad disc' - how can I fix this?
I solved this on my CH-DVD 300. The laser slides in and out on two rails. It's supposed to be in the far inside position to load/read a DVD. If it's too far out of position it does not automatically return to the far inside position on startup or eject/load. I manually pushed the laser assembly to the far inside position and now my player is working perfectly again.
The laser was evidently jarred out of position by a mechanical shock, or perhaps the power failed while playing a DVD and left it out of position.
May 29, 2009 | Televison & Video
No Disc
Check on for a service center in your area.
Aug 01, 2008 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Can't play dvd
Maybe your dvd got some capacitors dried on the power supply.
But you can also clean the laser lens maybe is dirty.
Jun 21, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD players not always beinvg able to load DVDs
You have bad filter caps in the power supply c10 and c11 need replaced and unplug unit when not using as power supply stays on always,,,,as long as its plugged in its on(P>S>) that is
Jan 02, 2008 | Cyberhome CH-DVD 300 DVD Player
Play cd's on my dvd
put cd in tray and let it load-then go to menu and hit button that says-play audio CD-your DVD player should also promt you when the cd is inserted with instructions for your peticular model
Dec 19, 2007 | Televison & Video
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
108 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
