Hi there My integrated washine machine is not working the best. Wheni have washed a load and then it finishes, it finishes with an 'FO2' sign, it then does not rinse the clothes properly and they are stil quite full with water. Can you please advise why it doing this.
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Washeer model KHWS01PWHO it does not seem to be spinning or pumping out water and the code is reading FO2 but drain hose is clear
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 13, 2010 | KitchenAid KHWS02R Front Load Washer
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
I have a Eurotech Washer EWF 172 Model # 20024321349 Front loading
hi
since u dint mention any specific question,i tried ti give u some generic answers along wth the manual of ur product
chek this link for the features of ur washin machine
http://www.dealtime.com/xPF-EuroTech-EWF172
OR
chek this file ffor the manual
http://dl.owneriq.net/6/65e593d3-7da5-4cfd-92dc-36e8365c1575.pdf
chek this link,for the all the generic probs related to washin machines...
http://www.repairclinic.com/0088_11_1.asp#Level1_3
OR
chek this link for more information
http://gowashingmachines.org/Washing-Machine-Drain.php
hope u will b helpfull
do let me kno,if u wanna kno more
regards
regards
Jun 20, 2009 | Washing Machines
FO2 Error Msg
ok now ,,check why water is not leaving machine on time,,,check your drain pipe,,check the drain hose,,just blow in it and make sure a coin not stck there ,,the same with the waste pipe,,onthejob
Feb 18, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washin machine won't spin
hi the problem you have is with the lid switch. located under the top replace this lid switch thanks the appliance doc
Oct 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washin Machine Spinning Problem
The main tub bearing is stuffed, thus the noise. The spindle becomes loose and the belt rides off. Bearings can be replaced.
Hope that helps.
Sep 07, 2008 | Hoover AL130 Front Load Washer
Indesit washeing machine
Karen, that was nice.........
May 31, 2008 | Indesit W 123 Front Load Washer
Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Nov 01, 2006 | Candy CN146 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
