Question about ION Audio VCR 2 PC USB VHS Video to Computer Converter
Problem with ion usb recorder-MixMeister
I have windows xp. I have the usb recorder connected to my turntable and to my computer. I have followed the installation directions and checked the sound and audio device-voice playback is my internal sound card and voice recording is usb audio codec. Everything looks like it is working but there is no sound through my speakers and no sound through iTunes.
Speakers work otherwise.
please help. thanks
4 Suggested Answers
  • 366 Answers
SOURCE: ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Posted on Dec 03, 2009
Testimonial: "Thanks that solved it!"
  • 32 Answers
SOURCE: ION Audio VCR 2 PC USB VHS Video to Computer Converter it record
hi, friend, the aHisoft Video Converter is just prepared for you, It is a Total Video Converter that can convert video to MP4/MKV/WMV/AVI and other popular formats such as: AVC, FLV, MP-1, MP-2, 3GP, 3GPP, Mov, M4V, ASF, SWF, VOB, DV, Super VCD, VCD, DVD and HD video.
so i think it will be helpful, you can search it on google
or visit http://www.asharer.com/
Have a nice day, my friend!
Posted on Aug 20, 2010
bronk50
  • 27725 Answers
SOURCE: I am running Windows 7,
what were the instructions you followed?
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Posted on Aug 30, 2011
How can I record from the turntable on my Ford Mustang Ion to my Ipod nano?
Advertising says;
4-in-1 retro music center with turntable, radio, USB and aux input
  • 3-speed belt-drive turntable plays all your records
  • Records your albums onto USB flash drive
  • Sensitive FM tuner with speedometer look
  • Built-in speakers and headphone jack for private listening; Auxiliary input for connecting and playing other devices
  • So record to USB, put the USB into the computer and transfer it using Windows File Explorer, using right click, drag, copy here, so a file location on the hard drive like 'My Music'. Then connect your iPod and transfer it. You may have to buy the 'iTunes Match Package' to allow you to use music not purchased from Apply. It is $24 a year.
    Amazon com Ion Audio Mustang LP Ford 4 in 1 Classic Car Styled Music...
    Apple Music vs iTunes Match What the difference
    Dec 27, 2017 | The Audio Players & Recorders
    Appears to be installed properly but doesn't record
    When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
      For Windows:
    1. On the bottom left of your screen, select the "Start" menu.
    2. Select "Settings" then "Control Panel".
    3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
    4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
    5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
    6. Under "Sound Recording," select "USB Audio Codec" for your default device.
    7. Check the box titled "Use only default devices".
    8. Click "Apply"...then "OK".
      For Mac:
    1. Open your Hard Disk.
    2. Open your "Applications" folder.
    3. In the "Applications" folder, open the "Utilities" folder.
    4. In the "Utilities" folder, open the "Audio MIDI Setup".
    5. In the "Audio MIDI Setup" under Audio Devices, set:
      • "Default Input" to "USB Audio Codec"
      • "Default Output" to "Built In Audio"
      • "System Output" to "Built in Audio"
    Now, all programs, including Audacity, will only use your internal sound card for audio output.
    Dec 26, 2007 | ION Audio iTTUSB Turntable
    How to connect ion turntable to bose radio?
    Why whole you try to connect a computer accessories to an audio system? Even when both things are made for audio.
    To bring digitising vinyl, closer to the computer user, ION produces record players, which don't output audio signals, but digital signals.
    The digital signals can be read by a computer, when connected to a computer with the appropriate software installed.
    If you want to connect the record player to an audio system, you need to rip it down. Trow out the digital part, and connecting correct cabling, straight to the cable coming form the PU element. Then you will be surprised, how little modern amplifies still can handle the low signal levels a PU element produces.
    I'm sorry I have to say you can't use the ION turntable in a normal audio system, like you can connect any USB connector to a normal audio amplifier, unless you modify the whole system. And if you would modify, the sound coming form that system, would sound poor, considering what you have to pay for the ION, and the modification. A normal record player, with a correct pre amplifier that can be connected to the Bose, would be cheaper.
    Jan 01, 2015 | ION Profile Pro Lp Usb Turntable With...
    I can't hear the music as I record it with windows 7 ...I could with XP
    hi,
    Check the version of your windows 7. If it is 64bit then it will only support usb devices which can handle 64bit. Try with windows 7 with 32bit.
    ok
    May 16, 2011 | ION Audio TTUSB05 Turntable
    Will the Ion Turntable work with Windows 7? I only see XP and Vista listed in the manual.
    If your ION turntable is a USB basedwith a USB plug it will work. Just plaug it into your USB posrt. A driver may need to be downloaded from the ION website for windows 7
    Dec 02, 2010 | ION Audio Audio Players & Recorders
    ION iTTUSB turntable has buzzing sound when I record
    It sounds like you have a bad ground on the tone arm. It's probably time to replace the tone arm wiring, or the external connecting cables.
    Nov 28, 2009 | ION Audio iTTUSB Turntable
    Need drivers for my ION Audio USB Turntable
    Hello
    USB audio turntable can be found on this site: Driver Update. have a nice day
    Jun 22, 2009 | ION Audio iTTUSB Turntable
    No sound
    Try setting the recordsettings of ur soundcard to "record what you hear". This way it will record ALL the sounds that are produced in windows. Warning: this also means that it could record an windows systemsound as well.
    Jan 01, 2009 | ION Audio TTUSB10 Turntable
    I cannot access the turntable thru my USB hub.
    I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
    Mar 10, 2008 | Numark ttUSB Turntable
    It doesn't work!
    with everything plugged and running go to preferences in FILE and set Recording Device and channels to Audio device USB in Audio I/O.Tick software playthrough.
    now set the microphone box to Stereo mix on the home screen(box is left of small scissors) hope this helps.nigel.
    ION Audio VCR 2 PC USB VHS Video to Computer Converter  Logo
    995 people viewed this question
    Top ION Audio Televison & Video Experts
     Grubhead
    Grubhead
    Martin Murray
    Lawrence Oravetz
    Are you an ION Audio Televison and Video Expert? Answer questions, earn points and help others
