Question about RCA Televison & Video
Model HD5OLPW42 50" screen LCD Serial #E115C401A I have a triangle shape dark place in the upper left corner of the screen.
I have a HDTV RCA and it will power off and restart itself after just a few second, can you help me determine what could be causing this.
Posted on Mar 21, 2013
  • 8 Answers
SOURCE: triangular shadow on the upper left corner
You may have a dirty or blocked mirror. You can usually take the back off and clean them. If you don't feel confident about it, a repairman can do it for you. If you clean it yourself, I recommend using a good quality glass cleaner and any type of towel that doesn't produce lint. Coffee filters work very well. Don't leave any streaks!
Posted on Oct 21, 2007
  • 1030 Answers
SOURCE: Dark area on screen
sound if u might have what is called a crt burn
Posted on Jan 03, 2008
  • 5 Answers
SOURCE: The upper left corner of the screen (triangular
This is your mirror tunnel. Light passes through the mirror tunnel to the DLP. The tunnel is made up of 4 mirrors glued together. Over time the glue comes apart and the tunnel shifts.
It starts out like this: |_|
and when the glue breaks down it does this: \_\
So the light, instead of passing through the mirror tube, goes through the ends of the mirror, so you get SOME light but not all.
I contacted RCA and they said:
"Ok, well sadly they do not offer the light tunnel anymore, which is what you need. Sadly you would be rendered to get a whole new light engine assembly. That would be the D.N.D module, light tunnel,color wheel,optic spanner, and oci. mirror. Your best bet would be to search ebay for a broken engine and replace it that ways. "
Awesome support! NOT! (That is the actual full text of the message from RCA support.)
I have some high temp epoxy and will be attempting to re-glue the parts myself.
Posted on Mar 22, 2010
  • 5 Answers
SOURCE: I have a 5 year old RCA 61LPW42 HD DLP television.
It's the light tunnel. The tunnel is a square tube made up of 4 mirrors glued together.
It looks like this from the side: |_| (with a piece on top too.)
When the glue breaks down, it shifts inside the little mirror holder. The shifted mirrors looks like this /_/ what you are seeing is the shadow of the tilted mirror tunnel.
ON the RCA's there's not a good fix.
RCA's response:
"Ok, well sadly they do not offer the light tunnel anymore, which is what you need. Sadly you would be rendered to get a whole new light engine assembly. That would be the D.N.D module, light tunnel,color wheel,optic spanner, and oci. mirror. Your best bet would be to search ebay for a broken engine and replace it that ways."
That is the ONLY response I got from them.
I took the set apart and found the 4 tiny mirrors. I will be attempting to epoxy them together. (The set is dead anyway, why not try?)
  • 1039 Answers
SOURCE: I have a Sony KDF-50WE655
The light engine needs replaced. Contact Sony. They have been replacing some of these even out of warranty.It is expensive.
Posted on Apr 01, 2010
I have a Samsung 4500 series plasma tv. Suddenly today the picture only displays in the upper left corner of the tv. its not due to the aspect ratio or zoom. What is causing this?
Contact the authorized service centre. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2014 | Samsung 4500 Series PN51F4500 51" Plasma...
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
Nov 26, 2012 | Televison & Video
I just bought a LG 55LX6500 TV, but I found when in dark scene or no signal, the screen showing very uneven darkness, espcially the 4 corners, the most the upper left corner a lot lighter than the rest...
it may be a problem with the backlight system.the leds use a edgelit led backlight instead of placing them directly behind the lcd panel. i suggest if it is very new take it back to the store otherwise you will need to call service technician LG should be able to give you contact info for authorized servicers in your area.
Dec 23, 2010 | LG Televison & Video
Where is the water filter located
Commonly its right under the freezer door in the grille area, you will see this big knob shaped item, turn this from east to west to north to south (counter clockwise a quarter turn) then pull the filter out, if its is a push button the button is usually triangle shaped and right next to the filter. Push it in till you here a click
The last two places in the upper right corner of the freezer OR the refrigerator section, if not in any of these three places you dont have one .
Good luck and hope this will helpout......
Aug 04, 2010 | Frigidaire FRS3R5EMB Side by Side...
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
I can't find where my water filter is. Model number GC3PEXN500
That model looks like a Whirlpool, I am very familiar with their set ups
We put the filter in two places
May 02, 2008 | Refrigerators
Dark area on screen
Jan 03, 2008 | Samsung HLN4365W 43" Rear Projection...
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Televison & Video Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
