Question about Minolta EP4000/5000 CS/PRO Copier
Code m2 erreur minolta 5000 - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Master
  • 6,680 Answers
M2 mean s to remove the Waste Toner box in the back of the machine. Replace with a new one and reset the counter in service mode.
Posted on Feb 07, 2015
2 Suggested Answers
SOURCE: how to clear M2 on minolta EP 4000/5000 cs/pro copier
how can i clear m3 code on minolta 4000 copier
Posted on Dec 12, 2009
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
Code erreur 46 40
Sir/Mam your copiers Hard Drive needs to be initialized.
Sep 08, 2014 | Konica Minolta Minolta Dialta Di5510 Laser...
Minolta codes m2
maitenance code, it needs to be cleared by a technician.
May 20, 2013 | Minolta EP4000/5000 CS/PRO Copier
MON PHOTOCOPIEUR AFFICHE LE CODE ERREUR L 6 SUR LE PHOTOCOPIEUR SHARP AR-205 DIJITAL QUE DOIS-JE FAIRE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Feb 09, 2011 | Sharp AR-M205 Copier
Minolta di 181 error code M4
QUEL EST LA SOLUTION POUR DESACTIVER L'ERREUR CODE M4 ?
Jan 21, 2010 | Minolta DiALTA Di181 Printer
Minolta Ep4000 show CodeM2
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
Mar 29, 2009 | Minolta EP4000/5000 CS/PRO Copier
We want to remove m2 after service code
Hello sir; After you set up all the PM cycle count you may press the "reset"key on the control panel.
Mar 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Minolta 5000 copeir
the only code that i see in the service manuel is : c0070, c0071 and c0072
All of these's code refer to the toner replenishing, check if your bottle of toner is correctly position....
To make sure, take the bottle out and close the front door, the copier replace the mechanism correctly, after that replace the bottle to it's position and close the front door....Please let me know !
Mar 27, 2008 | Minolta EP4000/5000 CS/PRO Copier
63 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
