Question about Panasonic KX-TG6072B Twin Cordless Phone
HOW DO YOU REGISTER A PANASONIC CORDLESS PHONE TO THE BASE CORREC
I UNDERSTAND THAT THIS IS THE SOLUTION FOR A "NO DIAL TONE" AFTER REPLACING THE BATTERY OR WHEN THE PHONE HAS BEEN SEPERATED FROM THE BASE FOR A LONG TIME, FOR REPAIR OR OTHERWISE.
leroyal
  • 2120 Answers
SOURCE: How to link 3 same model cordless phones to one base
Only if you have 2 phone lines.
Posted on Nov 06, 2008
RPFinney
  • 385 Answers
SOURCE: cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Posted on Apr 26, 2009
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
  • 5 Answers
SOURCE: My cordless phone says No link to base Move closer
This is the usual message that the phone gives when the battery has died and it has lost connection with the base unit. The usual fix is to remove and reinstall the battery, then place the unit on the charger for a full charge. This will usually fix the problem that you discribed. If after a full charge, you still get that message, you will most likely need a new battery. Good luck...
Posted on Nov 06, 2009
SOURCE: panasonic cordless phone no dial tone changed batteries
electricity went out for 10 hrs
decided to switch phones around----not phone problem
phone ok in all phone outlets in wall
it was plugged into fax machine--maybe electric power outage hurt fax phone connection for phone line
fax works fine, just can't work as did before with phone line into fax
will call brother #775 monday
all was plugged into power surge
maybe have to adjust something on fax or buy new one because of power outage????????????????
Posted on Nov 22, 2009
Www panasonic com help
make sure that the handsets are registered to the base.
if not, look at handset registration in the user manual.
Oct 12, 2013 | Panasonic KX TG6511 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Cordless phone not connecting to base. no dial tone.
or
Regards
Richard.
Apr 26, 2009 | Panasonic KX-TG5673 Trio Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
One of the handsets does not work. the other two handsets are OK
Probably defective unit.Try and get it replaced.
On another note, when these phones act like they are going to **** out on you in about a year (manufacturers often use the lowest bidder for batteries on these), replace the batteries with Energizer rechargeable equivalent. That exact scenario worked great for me and my older Panasonic setup is running 4 years strong on the Energizers.
Mar 03, 2009 | Panasonic KX-TG1033S Cordless Phone
I don't have a dialed one at all
Do you know the phone line that the base unit is connected to is a good phone line?
Have you registered the handsets with the base, as per the owner manual instructions?
Jan 27, 2009 | Panasonic KX-TG1033S Cordless Phone
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
Panasonic KX-TG6072B Twin Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
