Question about Baumatic B180SS And B60SS (Bundle) Electric Single Oven
No heat in oven
Hi there, i have a B180SS-B oven and cannot get heat from the oven element. the fan works but the bulb went some time ago. i have taken the element out but i cannot see any signs that its broken...please help
  • 1 more comment
  • ovenheat Jan 04, 2008
    no heat in oven as well, fan ok, light ok - how do I test to see if the element is the problem
  • olujr21 Mar 03, 2009
    my oven does not heat up the fan work and the light comes . the grill works B180ss-b
  • Anonymous Mar 18, 2014
    this is the model number from B&Q that is idential to my cooker
    Sergeant:
  • 236 Answers
The element may be open circuit, test it by a continuity test. the actual element is inside the metal outer surrounded by a ceramic compound -you will not be able to see any breaks hence the electrical test.
Posted on Jun 06, 2007
SOURCE:
Hello, I have a Baumatic B180SS (B600) oven which no longer heats up when i choose the fan oven option. The fan still works and if i change it to Grill it heats up still. Can you please advise me of...
we can not guess at any cost to repair . that is many times a local thing by your location in the world .could be a bad controller but only a repair tech can really tell for sure
Jan 14, 2018 | Baumatic B180 Electric Single Oven
My b180ss oven will not come on.the fan and light are ok.
I would definately say that the oven element needs replacing.
You will find this located at ther rear of the the oven compartment behind a removeable cover.
Apr 06, 2010 | Baumatic B180SS And B60SS (Bundle)...
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
Need to put new bulbs and elements in fan oven
the bulbs are screw fit normally Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jan 12, 2010 | Ovens
The fan oven is not heating up. The fan appears to to be operating and the element for the grill heats up . I had the oven element replaced over a year ago.
If the fan is working o/k, but there is no heat, then it is more than likely the element that has failed again.
The fact that you had it replaced a year ago, does not mean tha it will last a long tiime, it is quite common for them to fail in a relatively short space of time.
Take my advice and fit a new element.
Thankyou.
Dec 03, 2009 | Baumatic Ovens
Oven not heating up! Fan works. Grill works OK. Don't know what model it is? It's stainless with black hideaway buttons. It's a built-in Neff single oven. We had just roasted a duck, everything was...
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Jun 15, 2009 | Neff B1641 Single circotherm super...
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Baumatic B180SS And B60SS (Bundle) Electric Single Oven Logo
423 people viewed this question
Top Baumatic Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Pie-man
Pie-man
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
