Question about Craftsman Engine Assy 55 Cc Incredipull
How to change the clutch on craftsman 55 cc chain saw
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I have a Craftsman 14" chain saw model 358.355141.
A link to a PDF OM for your saw follows.
http://www.managemylife.com/mmh/owner_manuals/20938/CRAFTSMAN-Chainsaw-Gas-L0904399?brand_name_search=358355141+CRAFTSMAN
A link to an IPL (exploded parts list) follows:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358.355141/0247/1503220?pathTaken=
I think the Poulan equivalent saw is a "PP200". The likely problem is the clutch faces are abraded away (engine print-item 19).
CM Small Engines have a matching part number (530069193) in stock but it it identified as a clutch washer (530069197), I think it indeed the clutch mechanism pictured and suggest you call them.
http://www.cmsmallengines.net/clutch-assembly-washer.html
You might try cleaning the clutch faces as well.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
3. Most (99.9%) clutches have left hand threads (tighten it to loosen it). If a finger nail held in the thread and rotated clockwise comes off the shaft it is a left hand thread. If it pinches against the clutch it is a right hand thread.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Sep 11, 2010
  • 1015 Answers
SOURCE: I have a craftsman 16" 36cc chain saw. Engine
First thing is make sure chain brake is not engaged is so equipped. Next make sure that chain tensensioner is not to tight to allow chain to rotate. I wouuld remove bar and chain from saw and spray both several times with WD-40 and work chain link by link until they all move freely.Clean and lube guide channel on bar and make sure that bar is not dented or badly rusted.If all else fails replace bar and chain. Good luck and thank you.
Posted on Mar 14, 2011
Settings for carb. on a 42 cc chain saw
Initial settings are one full turn CCW on both low and high side adjustments.
Sep 02, 2014 | Craftsman sears 18" Chain Saw Chain (...
How to replace clutch model 316341070
See if there is too much tension on the chain. Is there enough chain oil on the chain? Go to the Sears Parts website to get the clutch.
Aug 27, 2014 | Craftsman 16" Electric Chainsaw Chain Saw...
Need clutch springs for a 2300av poulan
I am confused. Is it a sears saw or a poulan saw? If it is a sears saw you go to sears for the parts. If it is a poulan saw find a shop that repairs chain sawsand take it there. They will be able to find the parts you need possibly in stock.
Nov 06, 2013 | Craftsman sears 18" Chain Saw Chain (...
How to remove clutch from ryobi 20
remove side cover bar and chain clutch may use a special tool to remove
Oct 26, 2012 | Ryobi Chain Saw. 20 in. 46 cc Gas Chain...
How do I remove chain brake on craftsman 358.360690 chain saw
yes remove the side cover over the clutch two nuts hold it on
Aug 12, 2012 | Craftsman Garden
Craftsman chain saw repair manual
Its not hard! You need to purchase a tool that goes into your spark plug hole. You remove the spark plug, put this tool in the hole. This tool stops the piston from moving so you can remove the nut holding the clutch. The clutch is what the drive sprocket is attached to. The drive sprocket is where the chain fits on at the engine side. remive the bar and chain and you will see the clutch. Use the tool and then use a wrench that fits the nut on the clutch. be sure you know which way removes the nut. It could be opposite of what you think. some are left hand threads some are not. I think these are not. After you replace the clutch be sure to lube the clutch bearings. Most people don't know this! use a grease gun made for saws and insert it into the hole at the end of the shaft that holds the clutch. Also next time your saw cant saw through a piece of wood, do not give it gas to make the chain try and move.This is what burns up the clutch! If your saw stalls out, and you press the throttle and it still doesn't turn. Always allow the chain to move, pull back and lift up on the saw slightly to get the chain moving again.
Jul 09, 2012 | Garden
What is the fuel mix ratio for a husqvarna 55 rancher chain saw ?
33:1.............always mix it on the heavy side and you will never burn your saw up.........go to walfart and get a bottle of "gumout" octane booster and stick it in the gas and it will run better than ever.......
Dec 17, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftsman chain saw only runs short time
Craftsman is made by Poulan.
How old is the saw? Have you checked for split fuel hoses? Change the cc to model number (2.2cc Craftsman is often Model 2200 Poulan) and try to find an IPL http://www.ordertree.com/cms/illustrated-parts-list/9788.html. This will show hose routing. As a last resort you may try the "Chainsaw forum here http://www.arboristsite.com/. These are good guys but you will be flamed for buying a homeowner saw.
Lou
I'd put the filter back on.
Aug 09, 2009 | Poulan Garden
Owners manual for Craftsman 20 in chain saw, needed
Parts manual, have model # available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Mar 26, 2009 | Garden
Craftsman Engine Assy 55 Cc Incredipull Logo
16 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
