Question about Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Electrolux EW28BS71IS ICE Maker not working - Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Electrolux EW28BS71IS ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
sfgs
Posted on Sep 30, 2010
SOURCE: Electrolux EW28BS71IS ICE Maker - Crushed ice no
i am having exact same problem, also had repair men out mulitple times, i am ready to SCREAM. someone please suggest a fix
Posted on Dec 02, 2010
  • 2006 Answers
SOURCE: Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Posted on Jan 10, 2012
  • 2468 Answers
SOURCE: Electrolux EW28BS71IS ice maker cubes will not drop off finger evaporator because heater does not come on.
then the icemaker module (the white 4" X 4" control box on the end of the ice maker is bad
Posted on Feb 23, 2012
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
May 21, 2014 | Electrolux 15 Under-Counter Ice Maker...
Electrolux ei26ss55gs6
Good Morning Denise, thank you for allowing me to assist you!
If your ice maker has stopped producing ice completely, please check these tips, in this order:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Also the water shut-off valve or water-inlet valve, or both, may be faulty and if necessary either parts may need replacing. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it after proper diagnoses.
Best regards!
Nov 22, 2013 | Electrolux EW28BS71IS (278 cu ft) Bottom...
I put in a new ice maker ( the old one broke) and it only dumped ice once
Make sure the door switch operates the light in the freezer because power is supplied to the im through this switch. Insure the freezer is 15 degrees or lower, these temps need to be reached before the im will cycle. Access the blue tube on the blue valve, disconnect it and blow through it. If you cant blow through it look at the tube that comes from the ceiling to the ice maker and check for ice blocking the tube. If water is coming through the dispenser then the water line that feeds the valve is not frozen and you either have a bad valve or a restricted fill tube.
Sep 30, 2013 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Need wiring diagram for Electrolux EW28BS71IS
Sorry, only pics 150K and smaller are allowed (and this diagram is a monster)2_22_2012_9_01_07_pm.jpg
Feb 09, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Jan 10, 2012 | Electrolux Refrigerators
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
heatman101
sfgs
Jun 24, 2010 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
27 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
