Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WMA37 - drum not turning at all
My drum is not turning, even by hand. I know that this is a common problem, but what is the most common cause............I can then work my way through them
  • Hotpoint Master
  • 3,463 Answers
I have already posted a solution to this problem, and did not hear anything from you.
Are you no further on?
Posted on Jan 15, 2009
Very noisy spin wf860
hi if you turn the drum by hand can you feel a slite rumble if you can it will be your drum bearings common problem on a machine that has had alot of use
Oct 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint WNA64 has been making loads of noise during the spin cycle now the belt has snapped are the two conected?U
I say so think its drum bearing failure common on this machine is the drum noisy on its own try a hand turn and see could also be a sock stuck in it if not free....Please leave feeddback
Apr 08, 2010 | Hotpoint WMA64 Front Load Washer
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wma37 washes clothes ok but wont drain or spin
the hotpoint has a saftey factor built into it if the water does not drain it will not spin , the fault is the pump is blocked or broke or the sump hose is block this leads into the pump
to fix take the drain hose the grey one and put it in to a bucket and it will empty the water
if not the sump hose is blocked
if it emptys lie the machine on its side if poss with power off , if it will not lie on its side disconect the water hoses
look under the machine u should see the pump and the sump hose u can remoe this hose put lots of old towels down to catch the water check in side the sump hose for blockages
the pump this on the new models has hex bit screws on it to open check to see if it move freely it should spring back slightly
try this any problems let me know the model number
Jun 28, 2009 | Washing Machines
Hotpoint Aquarius WMA37 - the drum is not turning, even by hand
Remove rear panel of washer, slip the belt off, then try the drum to see if it turns, if it does, then the motor is the problem, if it does not, then the main bearings have siezed, or there is something fast between the inner and outer drum..
If it was noisy on spin prior to this happening, then it is more than likely the main bearings that have siezed.
Plz rate my solution.
Thanks.
THAN
Jan 10, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Drum does not turn
The most common problem is with the belt drive.
Try this test. - Open the door, rotate drum by hand - is it free to rotate without any noise of driving the motor around? - If it is - order a new belt for it.
If you can hear the motor turning, try running the machine again. If movement is erratic - you need replacement motor brushes.
If you think the motor is dead, it may be - or there may be a fault on the control board. Both need testing to see. Usually one will need replacement.
Jan 05, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint WMA 22 drum not turning
Hi, common problem with this make of machine but easy to repair. Take off the lid and make sure it is un plugged from the mains...... You will need a pair of hook nose pliers to remove the carbon brushes from each side of the motor. They should be an inch long if not there is your problem.. Just replace and it will run.
Let me know how you get on..........
Nov 24, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Remove drum paddle from hotpiont wma37 washing machine
Hi.
Firmly grip the paddle, and pull it towards you, this should release same. When you put it back, locate the paddle in the slots, and push firmly away from you
towards the rear of the drum
Good luck
Nov 22, 2008 | Washing Machines
Hotpoint wma37
Hello
Well to change the drum bearing on your machine is pretty straight forward if you have some sort of mechanical grasp but pretty much impossible if you dont..
the procedure is
first take of the top lid two screws either side and it comes off by lifting thefront end of the top and a slight push back and off ...
Then take out the soap draw and undue the 3 screws there.. remove the control panel by unclipping all the wires..
Then the front panel with door you have to remove the 3 screws at the top and 3 at the bottom undue the screws by the door lock and remove the ring around the door gasket and detach the gasket from the front panel.. then simply lift the panel upwards and it will come off..
the remove the rear panel..
Then undue the weights as it will make the job eaiser..
Then remove detach the rubber pipe leading int o the drum from the bottom of the soap draw..
then detach the wire from the solinoids at the back and unlip the little tube that is attache to the pressure switch don not remove the wires from the pressure swtich..
then at the rear of the machine behind a balck cover are the heater wires remove the cover and the wires. you will see at teh bottom of the machine that he wire are held to the drum via tie-clips remove cut all the clips as you will have to replace them after wards..
then remove the wires from the motor ..
then remove the pegs that hold the legs in place which connect to the drum..
then you know the metal panel which the control panel was connected to undue that now. and throw it ove complet with the wiring loom and pressure switch to the right hand side of the machine,,
now unclip the little white things on the top at the sides where thesprings sit and take out the drum...
detach the motor from the drum and remove the springs
The drum has 16 screws around it undue all theses they are star T-10 i think. undue all of them and split the drum open ...
undue the fly wheel and remove the inner drum ...
get your hammer out and knock out the bearing you might need some kind of small bolster or punch.. to remove these and if your bearings are damaged badly then your your probably end up with the outer cone stuck to the bearing shaft,,, be paitient clean it wd40 it and eventually is should come out.. now if you need anymore help then let me know
cheers vaccs../..
Jan 04, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
101 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
