Question about LG Ovens
Old GE Oven Model J 479003 (from the 1950's does not regulate temperature
Two side by side ovens. Large oven does not properly regulated heat. Also, indicator light stays on all the time even when the oven is off
SOURCE: oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Posted on Oct 22, 2007
watugot
  • 290 Answers
SOURCE: OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Posted on Nov 24, 2007
SOURCE: aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Posted on Apr 20, 2008
Macmarkus
  • 2605 Answers
SOURCE: Large oven doesn't heat up. Heating element gone??
Hi, In a word yes. As for who you can contact, I'd suggest only an authorized b/s/h (bosch/thermador/gaggenau) service provider. I used to be one for over 10yrs. but now work exclusively for sears...I'm not sure if I made a good choice or not yet, lol ! I digress. It is quite possibly not even the element as the gaggenau have cut-outs (they are actual thermal fuses that cannot be reset, they must be replaced) built into the bake circuit that can open often times. This of course unless you're certain the bake element is defective. Check your local directory under appliance service or a vendor who sells that line may be well equiped to direct you for quality service in someone they trust and are proficient. Hope that helps, good luck. macmarkus :)
Posted on Nov 10, 2009
barkencoa
  • 3463 Answers
SOURCE: fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Posted on Dec 15, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Fagor oven will not regulate its temperature, once
Hope this helps.
Dec 15, 2009 | Fagor 5HA-196 X Single Oven
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
Ovens Logo
44 people viewed this question
Top LG Ovens Experts
Coss
Mike Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
