Question about LG Televison & Video
Why is my lg 32ls3500 not auto detecting channels via my sky box
I have tried tuning using antenna and cable options through autotune but the set cannot find any channels. I have tried with the sky box on menu and on a channel but still no channels detected.
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Posted on Oct 09, 2009
  • 55 Answers
SOURCE: how to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Posted on Nov 01, 2009
  • 5062 Answers
SOURCE: LG TV loses channels when turned off
Is your location prone to power surges or failures? Try plugging your TV into an uninteruptable power supply (UPS) (battery backup and line voltage conditioning). If that doesn't help, I would be suspect the unit has a problem with the internal memory.
I hope this helps.
Posted on Apr 18, 2010
  • 11800 Answers
SOURCE: I bought an LG 32LD460.
The tuner inside the tv has failed - which is quite odd since you just bought it. Take it back and recover your money, you got a lemon.
Posted on Aug 09, 2010
I HAVE NO IDEA HOW TO TUNE IN MY T V HAVE ALWAYS USED MY SKY REMOTE BUT AS BOX IS BROKEN I AM NOT GOING TO USE SKY ANY MORE PLEASE HELP AS CANT WATCH ANY TV AT THE MOMENT
first off you need an antenna attached to the home and TV the you do a channel search through the main setup menu. the antenna ,unless it is a 360 degree type needs to point in the direction of your local stations .otherwise you may not find all that are there . GOOD LUCK
Sep 15, 2015 | LG Televison & Video
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
CANT TUNE IN
You must connect an Antenna to use the AutoTune. A set of rabit-ears is sufficient for most areas: RE: the Digital (Free) TV singals are using the old UHF/VHF frequencies - so any antenna designed for Broadcast TV should work. Connect your antenna to the ANT/Cable connection then re-run the Auto-Tune again.
Jan 10, 2015 | Televison & Video
How do I repair an LG 32LK330-Ub Auto channel tuning does not work.
If you have a cable box and your cable is attached with coax to the antenna or cable input you're probably receiving everything on Ch 3 or 4. If you don't have a cable box, then make sure the input / source is set to cable and not antenna.
Dec 03, 2014 | LG Televison & Video
Can you watch the same sky channel on 2 tvs
Yes if you use the rf2 out on the box, cable it to the aerial input of the tv in the other room using uhf coax cable (aerial cable), and tune the tv in analogue mode (not freeview but the old analogue) to the sky box. It's usually on CH68 but if you do an autotune it should find it. Of course you will only be watching in SD not HD on the second set.
Jun 19, 2014 | Computers & Internet
I am in Afghanistan, Kabul Area. I have an ALT2260M Avol tv. when I use the autotune for channels, All I get are the local channels. We are hooked into the AFN Network cable and it does not pull those...
try going into the autotune then select us then cable select the auto acan then change from auto to irc or std then scan should do the trick.
Dec 06, 2010 | Televison & Video
I got an American model of LG. i can not tune it by auto nor manual can you please help
You can get a manual here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LG30.jsp . Click on the Support and then on the right hand side look for User's Manuals. Since the TV has a tuner for ATSC, NTSC, and Clear-QAM, the next question is what is your signal source? (analog, digital and unscrambled cable)
If you are using OTA, make sure that the input is set to Antenna. Use antennaweb.org or tvfool.com to check the direction to point your antenna and the appropriate antenna for your distance to the transmitter. antennaweb assumes an external antenna and is very conservative in the list of channels you should be able to receive. tvfool gives the stations available with different antennas. If you have several tvs connected to one source, you may need an amplifier in addition to the splitter. This also can help marginal signals come in since digital is either enough for the tuner to resolve or no signal. (Check splitters and amplifiers if you suddenly can't get a signal that you used to receive. Also check if the antenna has been turned.)
Menu > Channel > Auto Tuning or Manual Tuning. If Lock System is active, you will need the password. Auto Tuning only searches for digital or cable channels. The manual tuning option should provide the signal strength as well for digital stations (as well as letting you search for analog signals or all signals (digital, analog, cable).
Use the input Cable for coax cable connections. Other inputs will not allow you to search for channels since they are meant to be controlled by the set-top box feeding the system.
I hope this helps.
Nov 05, 2010 | LG 32LG30 32 in. LCD HDTV
No tv channels with Philips 42FD9935/17
If you are using a Cable Box, then select the Cable Box option in the TV. If you have connected the Antenna directly to the TV, then select the Antenna option in the TV under Menu options. Try performing the Auto program.......If using a Cable Box, then no need to perform the Auto program. If the issue persists, try resetting the TV to the factory settings and check if it helps.
Jul 25, 2010 | Philips FTR-9964 Tuner/Receiver for Plasma
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
properly connected.
set.
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Televison & Video Logo
26 people viewed this question
Computer Repairing
Computer Repairing
