Question about Kodak Easyshare C182 12MP Digital Camera
My sd card is stuck in my kodak easyshare c182, how do i get it out?
It is not in upside down, and has been "protected" prior to insert. Is there a way to get it out? It springs out when pressed on like normally does, but when I go to pull out it is stuck. I tried to light tug on it to get it out, but to no avail. We have no camera repair shop around that we can bring it to. HELP!
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, Sorry to say you will need to send it out for repairs, There are shops available on the web that can make arrangements to mail it to them for repairs.
Posted on Jan 24, 2013
  • 203 Answers
SOURCE: just bought a 4gb kodak
No way-that model will not support a 4gb card-yes it may fit but camera is to0 old for newer sdhc cards-go back to 1 or 2 gb max and no problems! 4gb only work on cameras within last 2 years
Posted on May 24, 2008
SOURCE: why is the camera stating memory card is full?
Hello, I have the same camera, I went to buy a Kodak memory card and the Representative was kind enough to ask me what digital camera, he said that the c330 will only take a 1GB SD Memory Card. Hope that helps.
Posted on Dec 05, 2008
SOURCE: kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
Posted on Mar 13, 2009
vortash
  • 431 Answers
SOURCE: i have a problem with my kodak easyshare C310 digital camera
Hi I am Vortash It sound as if you have a damaged pin on the sd card reader within your camera , and it is not reading the cards id correct . It may be just a result of dirt on the pins ( grease from hands touching the sd cards causes problems ) simply try spraying the inside of the sd card slot with a good quality electronic switch cleaner , then put the card in and out a few times to rub the contacts . ( Clean the sd card with the switch cleaner and a clean cloth or tissue first )
CAUTION when spraying the sd card slot make sure the batteries are dissconnected and give the camera ample time to dry before re inserting batteries ..if this fails then a service department will be able to check the reader out for you . ..Hope this helps regards Vortash
Posted on Jul 07, 2009
leepania
  • 1099 Answers
SOURCE: Can't format 8 GB SD memory card
The camera doesn't support this memory card.
Memory card support : SD/MMC up to 2 Gigabyte only.
Sorry you will have to downsize.... :)
If helpful pls. rate me and/or recommend me TXS
Posted on Dec 03, 2009
Whats the largest size memory card i can put in my kodak easyshare c182 camera
The C182 uses SD cards which max out at 2GB and SDHC cards which max out at 32GB, so 32GB is the largest size card you can use.
Apr 07, 2014 | Kodak EasyShare C182 Digital Camera
Unlock memory
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 24, 2014 | Kodak Easyshare C182 12MP Digital Camera
Kodak EASYSHARE C182 , memory card not formatting !!
Sometimes these memory cards have a small (switch) tab on the side of them which needs to be in the correct position.
Check it out and slide the tab fully to the other position
Oct 12, 2017 | Kodak Easyshare C182 12MP Digital Camera
I have a Kodak easyshare c182 camera and my memory card says it is protected and then says to reset switch on memory card how do I do that
Dec 11, 2011 | Kodak Easyshare C182 12MP Digital Camera
When i insert the memory card in my Kodak c143 east share then i displayed that " memory card is protected (reset switch on memory card)".
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 24, 2011 | Kodak EasyShare C143 Digital Camera
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
The camera says that my Memory card is protected. How do I unprotect my pictures? Also how do I reset switch on memory card? Thanks
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If you had protected any pictures on the card, then while viewing that picture press the Menu button. Use up/down to select Unprotect.
Oct 13, 2010 | Kodak Easyshare C182 12MP Digital Camera
Memory card is protected not able to take pictures at this time...I can only review the memory card in the camera
Aug 30, 2010 | Kodak Easyshare C182 12MP Digital Camera
HOW DO I CHANGE THE SD CARD ??
These are the physical specs of Kodak Easyshare V530
The bottom and the top of Kodak V530
The left side and the and the front of Kodak V530
The back -lcd display and the right side of Kodak V530
On the right side of the Kodak v530, just look at the above image, you will see a slot in the center of the silver band covered with white felt curtain that protects it from dust. On this slot is where the SD card is inserted. Just insert the card carefully, and feel the click when SD card is placed properly, and push the card carefully until it bounced back and release from the slot when removing the SD card.
Jul 18, 2010 | Kodak EasyShare V530 Digital Camera
Kodak Easyshare C182 12MP Digital Camera Logo
52 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
