I have a m/region DVD player but the TV will not play region 1
I have a multi-region Panasonic DVD player but when I put on a region 1 DVD the television set comes up with a message to the effect that the television cannot play it. I have checked the manual for the TV and gone through all the menu facilities on the TV but cannot find any means to change from the PAL system to the US system. Can you assist?
    Genius:
  • 1,239 Answers
Basically pal and NTSC do not play any part in the DVD region coding process. Pal and NTSC simply mean the difference in the various tv formats. PAL is the UK tv system which runs at 50Hz (update 50 times per second) and NTSC is used across Europe, America and most other parts of the world runs at 60Hz.
Region coding is something different. This is basically a system that only allows DVDs to be played in certain regions. The UK is region 2 along with Europe and other countries like the Arab Emirates. Region 1 is the USA. There are 8 different regions, 9 if you include 0 which is basically 'region free'.
Most DVD players have some sort of 'Hack' which will allow you to change the region code of the player. This normally comes in the form of a code that is entered on the remote, which sometimes reveals a 'secret menu'.
One of the most common 'hacks' for Sony DVD players is this one however you will need an 'AllInOne' Remote.
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
Press the DVD button
Hold down the Magic button until the unit performs a double LED flash
Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
Press the Magic button once
Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Posted on Jan 10, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 10, 2009
    There are various websites out there who will charge you a fee to send you an unlock code for your DVD player. I heard Amazon do them. You'll have to put in the exact make and model of your player and they'll tell you if it can be "unlocked".
    Try this link:
    http://www.dvdcodes.net/
  • ABHISHEK.C
    you can hack the dvd player if it is possible, PAL is the format that is common in the European side, NTSC is the format for the American side.
    try this site
    http://www.videohelp.com/dvdhacks
    Brigadier General:
  • 5,158 Answers
Does it in fact say in the manual that it is multi region ?
How to make region free dvd
Usually a region 1 DVD player will not be able to be a multi region because it needs to be able to convert between pal and NTSC to play on your NTSC TV. Unless the player is a European model then it would be possible!
Oct 01, 2015 | Panasonic DVD-CP72 5 Disc DVD/CD Changer
Incorrect region for panasonic dvd player
The player is set to a fixed region relevant to the country you are in for play back of DVD disks and the disk you are trying to play is not compatible with the country you are in! You need a multi region player or to have your current player unlocked to be multi region! Which country are you in?
Oct 02, 2014 | Panasonic Televison & Video
PANASONIC SC-BT200 UNLOCK REGION CODE
Google for "Panasonic SC-BT200 Region Free
Also see
"http://www.avforums.com/forums/blu-ray-players/885440-blu-ray-player-multi-region-hex-codes.html"
Some Blu-Ray players will need a hardware mod to be region free.
Feb 05, 2010 | Panasonic SC-BT200 Home Theater Systems....
Make dvd player into muilt region so it plays all dvds
hello.go to your setup
there will be a tab that says regions
select region 2 that is multi region it will play regions 1-4
May 11, 2009 | Televison & Video
I need the region dvd code for my panasonic triple play tv
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Nov 11, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Multi region code for DVD
You need to hack the dvd reinstalled firmware, I can see if I find hacked firmware for your dvd
May 01, 2008 | Onkyo DV-CP704 DVD Player
Multi regional DVD player?
To my knowledge, yes it is. The Panasonic NV-VP32 will play all DVDs.
However, to be able to view multi region DVDs (PAL/NTSC), the Panasonic NV-VP32 must be connected to a multi system TV (capable of both PAL/NTSC).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Panasonic DVD-S52 DVD Player
Locked dvd
Mar 02, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Help
HI,
it depends on whether the drive is multi-region ?
Some drives are region Set, i.e Region 1 ( NTSC-USA )
Region 2 ( UK PAL )
Most Players Are Region Set, To the country they are purchased in, you can sometimes set the player to become, multi-region, via various buttons on the remote or by the front panel.
I offer a service to unlock 99% of DVD Players, to play all or many regions.
We do have a charge for this Service.
Many Thanks mike @ Compurepair.
Feb 27, 2008 | Televison & Video
Panasonic dvd-cp72
asptroy,
hi mate, just want to know first if what region indicate at the back of your DVD player? the reason why i ask you, is because most of branded DVD have their own region for ex. for asian countries they are tagged as region 3 and Australia region 4 ...... most probably your player is not configured to play multi region disc if it can't play any disc. The only way to check if your player have a problem is to check the region of your player and if you can barrow or buy a dvd disc having the same region. or simply check for DVD disc which indicates that it is a all region compatible. Actually this is only info that i can share, but if your only near in my place i can help you change your dvd player to become a multi disc reader simply by clicking some activation keys using the special remote control specially design to configure and modify region setting of panasonic players.
cheers,
markiez23
Jan 05, 2008 | Panasonic DVD-CP72 Multi-disc DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
