Question about Panasonic Proline AG-DVC7 Mini DV Digital Camcorder
My external mic wont work! Please help.
Im a week away from beginning production on my new project, and I cant get my external mic to work with my Panasonic ag-dvc7. The mic is xlr, so I bought an adapter to go with it. The mic works with other cameras, so I know it works, but it just wont work on mine. Can someone please help me, if anyone has ever had this same problem. It would be greatly appreciated, thank you! -Michael
  • 2 more comments
  • Michael DuBois Jun 07, 2007
    I didnt rate anything, I just clicked that I needed another solution. I never rated anything. And yes, I said that the mic works with other cameras. So yes, it does work. Thank you.
    Alright, thank you techman. Yeah I figured I would probably have to bring it in some place, but I figured it was worth a shot to ask people. Thank you very much man.
  • Michael DuBois Jun 09, 2007
    Thank you so much for being so kind and so helpful. Here, Ill post the links to the kind of mic and adapter I have...
    mic- http://www.azdencorp.com/shop/customer/p...
    (and I just read, that IS phantom powered...)
    and the adapter- http://www.studio1productions.com/xlr-bp...
    again, thank you so much. You have no idea how happy this made me to come on here and find someone ready to fully help me. Thank you. Talk to you soon!
  • Michael DuBois Jun 12, 2007
    Novelist:
  • 198 Answers
Hello, I'll try to help you by begining with a small description of the microphone connector you have. An XLR connector is a balanced type of signal connector. It means that it has 3 pins, one is for ground connection, on for signal positive and one for negative signal. Your camera woun't need those pins, instead it needs only a ground connection and a signal pin (2 pins). You need to use an adapter but this doesn't solve all the problem. You should either tell me the model of your microphone because I need to check if it's a Phantom powered microphone (it means one of the pins of it's XLR connector carries a 48 volts connection that is needed to power on some components inside it's casing). Phantom powered capacitor microphones also uses XLR connectors so we need to make shure if the microphone is compatible with the camera. Just tell me what's written on the microphone and I will check for you. If it's not compatible (if it's an XLR phantom powered microphone) you will need to search for another one because these microphones are made for using in live sound mixing aplications (concerts, studio recordings etc). If it's compatible, I will then instruct you on how to adjust the adapter in order to have it work. Please don't try to connect it any more untill we clear this out because an incompatible microphone can damage the camera's microphone amplifier circuit. Also please don't try to connect another adapter meanwhile. I'll reply to you as quick as possible. Thanks for understanding and patience.
Posted on Jun 09, 2007
  • Motoi  Bogdan
    Motoi Bogdan Jun 09, 2007
    Also, please note that some profesional cameras have an Phantom Powered output for these microphones and altrough the microphone works for them your camera may use a different output. I will check this also. Also if the microphone uses symetric signal carriers (balanced type of microphone) it can also mean you need to make some modifications on the cable in order to get it working with this camera. Don't worry however, we will get to a simple answer in no time.
  • Motoi  Bogdan
    Motoi Bogdan Jun 13, 2007
    Hello again,
    It appears that both links aren't working, I've tried clicking them but both result in server errors. However the problem is pretty obvious. Since your microphone uses phantom power to work, your camera should have had a 48Volt special connector in order to power on the microphone. In this case you woundn't have needed an adapter because all phantom powered mic's use XLR connectors. In your case the adapter you have isn't suited for the purpose needed since it's a simple mechanical swich to make the devices cables connect to one another.Therefore it can't produce the 48volts needed to power on the microphone. Please note however that there are 2 main types of XLR connections. One involves phantom power (your microphone for example) and another involves balanced signal wires (used for some audio devices such as mixers). Both connectors look the same but their porpose is different. it's a common confusion that may appear.
    In your situation the things aren't that good. The microphone is simply not compatible with the camera. Since the camera doesn't have an external +48 Volts source, this microphone woun't work, whatever adapter may be used. Furthermore it can damage the camera microphone audio amplifier circuit because of low impedances these mic's have when unpowered. I don't recomand you to try to swich on the camera when using this microphone. The solution to this problem would be another microphone. Most full sized microphones will come with a standard audio jack and those that come in this way don't require Phantom Power. It's the simplest way to recognise them in future. Sorry for the inconveniences and the delays this microphone may have caused to you. Hope these advices help in the future and if you have further questions please feel free to ask.
    President:
  • 3,130 Answers
Ilovefilm3, Yoo never said if the internal mic worked or not. Oh and by the way, if you rate this thread bad , we cannot help you if we have another idea, as you cannot change the rating once it is done, so if you really want assistance, please dont be so quick to rate this thread till we are done asking you the questions about your problem. Thanks
Posted on Jun 07, 2007
  • Larry  Dillon
    Larry Dillon Jun 07, 2007
    Then your problem hs something to do with the XLR adaptor, or the mack jack has a broken connection on the inside, or there is a bad coupling capacitor from the mic jack to the preamp board. Good Luck, PS I would take this unit into be checked out by a pro, as there is nothing more you can do my friend.
    Scholar:
  • 125 Answers
If the mic is working on other camera's, what about the adaptor ? If there is a possiblity of checking the mic and the adaptor together on other equipment ? Use another mic with the same plug as the camera, ie. PC microphone (you can even test by using an earphone, the earphone can be used as mic) If it works then the XLR mic with adaptor is the problem. If ther other mic (used for testing) also did not work then the microphone jack (socket) in the camera is defective or the gain setting of the camera is set to minimum.
Posted on Jun 06, 2007
I cant connect my dtvpal converter,my indoor old antenna, to an old 19 portable tv? please help
Since they began broadcasting digital you will need to get a converter from Radio Shack. Might be easier to just get a flat panel TV.
Sep 20, 2014 | Televison & Video
I have an HP Pavillion dv2700 laptop with windows Vista. My mic was working fin until a few weeks ago, now no one can hear me on google voice or skype. I checked the mic settings and it is not muted and...
You can try going into device manager and find the device and remove it then reboot and let it reinstall the mic drivers. If that does not work try going to the HP site and see if a new driver is available and install it. The mic could have gone bad and you may have to buy an external mic.
Thanks for using FixYa
May 30, 2011 | HP Pavilion DV2910US Laptop
Mic to PC
This mic is a condenser type microphone. It needs phantom power (48v) to operate. Might want to buy a USB mic preamplifier box, like an M-Audio product, which will provide phantom power, xlr/1/4 inch inputs and USB output.
May 23, 2010 | Behringer C-3 Professional Microphone
Radio squeal.
Check it with the external speaker unpluged, turn the mike gain down a little at a time, until it does not squeel. ..hope this helps..
Mar 20, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Power problem
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from www.TvRepairKits.com for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
0667c5f.pngSOLUTION
Its a fairly easy DIY job. Check the site www.TvRepairKits.com
Their kits include a photo instruction guide, parts, email/phone support, etc.
Dec 02, 2009 | Philips 60P8342 60" Rear Projection...
My mac wont see my drive anymore?....i have had it for over a year.....the drives light blinks but my desktop wont see it anymore?...... it is a lacie 500giger external 800 firewire.....im panicking!!!...
Hi Scott,
Don't panic too much, as stressful as this can be you have not yet lost anything. Step one, if the light blinks you have power, if you aren't getting any warning issues and it doesn't show up, chances are the circuit board in the Lacie may have fried.
Go to your local PC shop and ask the techs there to extract the actual hard drive from the lacie enclosure and test it in a new enclosure. If this works, no biggie, by the new enclosure and you're on your way.
If it doesn't work in the new enclosure then the problem is in the hard drive itself which is more serious but can still be dealt with.
If it fails in the new enclosure comment back and let me know I will refer you in to a facility in SoCal or a smaller less expensive one in Canada if you can wait a week longer to have your files back.
For the future, one you have your drive working or your files recovered remember that us data recovery specialists NEVER trust any drive. They can and do fail so as a recovery pro myself I have 3 inhouse levels of data, Data on the machine it's created on, all those machines back up to my home server and then it backs up to an external similar to your lacie. I also exchange externals every couple weeks with my father who lives a few miles away so if the house was burgalerized or god forbid burned down I will still have all my data to within two weeks at dad's house.
I do this a bit more severley than most people but I also deal with crying people on the phone every day who are either happy to have their files back or sad because they cannot afford the process required to retrieve them.
Let me know how you make out with the new enclosure and if it fails wether you'd like a 1-2 week turn around time for a little more money or a 2-3 week turn around for less money.
Chris
Sep 12, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Mic stop working
Open Sound devices from Control panel & do the following
1. Click Advanced button in Volume tab
2. Select Properties from Options menu
3. Click Recording & press ok
4. Now select Internal MIC
Hope this solves your problem
Aug 03, 2009 | HP Pavilion dv7 Keyboard (483275-001)
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
PROBLEM WITH MICROPHONE
i have the same problem..can sm1 plz help? :'(
Apr 21, 2008 | Audio Players & Recorders
No sound
If the webcam have mic and have installed another external mic on pc remove external mic from pc....
Go to the msn msgr and go TOOLS - AUDIO AND VIDEO SETUP and look there if ur mic working
Nov 18, 2007 | Creative Labs WebCam Live!
Panasonic Proline AG-DVC7 Mini DV Digital Camcorder Logo
183 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
