Question about Wharfedale Televison & Video
Receiver switches off when standby button is pressed
Hi all I have an old warfedale receiver, wav 4313, that has gone faulty and I would be grateful for any help. When switched on and in standby mode, the led is on and all is fine. However when pressing the standby button the display lit and went off a couple of times, now whenever the standby button is pressed the machine switches off. I know this is a very old unit but if anyone could advise whether it is repairable or not I would really appreciate it. also is it a particular component that can be replaced. Many thanks in advance
SOURCE: my sony receiver is stuck in protect
I've had a Sony STR-DE725 for years, and it's always worked fine, until recently. When I turn it on, instantly, or within 1 minute - it will "click" and then display "PROTECTION". Like any good DIY'er, I googled everything - so I looked for any loose speaker wires, and finding none - decided to open it up. I pulled it out on my workbench, opened up the case, and blew out about an inch of dust from everywhere with an air compressor. Next I disconnected and reconnected every connection that I could easily reach. Finally, I unscrewed (about 1/4 turn) and re-tightened every single screw that I could reach in the guts of the receiver. It works fine now! Go figure... probably the dust, or a loose connection somewhere. Definitely try this first, as you have nothing to lose but 30 minutes of your time on a weekend!
Posted on Jul 08, 2007
DJYar
  • 41 Answers
SOURCE: wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Posted on Aug 23, 2007
SOURCE: Ultimatetv receiver troubles
Seems that the hard drive may have died. try replacing the hard drive with a new ide hard drive that's under 120 gigs. then the front of box will have some lights flashing for awhile. It is formatting the drive when it is doing that. Once done flashing you will get back to the webtv screen. It should then call up the webtv toll free number and then from there call up your local office. it should download over a hundred or so files to reprogram the missing guide and dvr software. once it reboots the tv funcations should return . It should act the same when you have a power outage ie downloading the latest guide info. you should have the tv back at this point. If you have problems still with missing channels or says you have not paid for programming , then you need to call directv. now it also have more disk space if you were using the orginal 40 gig hard drive , your new 120 gig should be about 100-110 hrs of worth of recordings. Don't bother with a bigger drive it will not format anything higher than a 120 gig drive. good luck if you still have it
Posted on Sep 17, 2007
SOURCE: Audio problem with B&K AVR507
I have the exact same problem with my AVR 307. Called B&K and they are familiar with the problem. Send it to them and they will upgrade your unit for no charge.
Posted on Nov 07, 2007
  • 74 Answers
SOURCE: Receiver on but not working
call direct tv and ask for a reset. When you do not use your receiver leave it on and connecetd or it will not receive updates and will forget what it once knew. Actually I think you can use the automated system and use (I think...not sure) code 712 to reset all your receivers with out waiting for help.
Posted on Dec 23, 2008
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at askOnkyo@us.onkyo.com, Thanks,JT
May 04, 2015 | Onkyo Audio Players & Recorders
When in video mode only plays through one front speaker
Hi Richard please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Apr 01, 2015 | Onkyo HT-R560 Receiver
TX-SR333 Bluetooth worked the 1st time now won't pair up.
Hi, Please try the following reset and then try to pair again.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "CBL/SAT" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Feb 27, 2015 | Onkyo TX-SR333 5.1-Channel Home Theater...
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
Yb125 battery wont charge
Instructions
    • 1 Check the main power cord if the receiver fails to turn on. If it is unplugged or loose, securely plug it in to an electrical outlet. If this fails, try plugging the receiver in to another outlet. If the receiver starts, the previous outlet is damaged. Call an electrician to repair it. If this fails, try turning the receiver on with the remote. If this does not turn the receiver on, try turning it on with the power button on the receiver itself. If this works, change the remote's batteries.
    • 2 Leave the receiver in "Standby" mode if it immediately goes into "Standby" when you turn it on. With the receiver still in "Standby," unplug the main power cord. Wait for around 30 seconds, then plug the receiver back in.
    • 3 Check the audio cables if you experience sound issues. If they are loose or disconnected, securely reconnect them. If you still do not have any audio, press the "Input" left or "Input" right buttons on the front panel to select the appropriate input source. You can also set the receiver to automatically detect input signals and select the appropriate input source. To do this, access "Audio Select" from the main menu and select the "Auto" option.
    • 4 Try factory resetting the receiver if you experience persistent audio or video issues. Press the "Standby/On" button on the receiver's front panel. Press and hold the "Tone Control" button, then press "Standby/On" again. Select the "Preset" option, then choose "Reset." Press "Standby/On."
Jan 14, 2013 | Yamaha Motorcycles
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
How to reset the recever?
Place the receiver in Standby mode (press the front-panel Standby/On Switch so that the Power Indicator turns orange).
Then press and hold the front-panel OK Button on the Receiver ( not remote ) for at least five seconds until the RESET message appears in the display. Then press OK. The system will go to factory default. All your settings will be lost like FM stations / Sound settings etc: .
Apr 03, 2011 | Harman Kardon AVR 35 Receiver
My rxv 1800 wasnt used for probably a year but was left plugged to a wall outlet during that time it wasnt used. when i came home last week, i switched it on but immediately shuts off after a second. when...
r this one: Switc off your receiver using the main power button on the front face. Hold the the Effect button and the Direct button, and turn the main power ON.f it ain't working, try this one: Turn your receiver ON and, while holding down the [VCR1] button, press the [STANDBY/ON] button. "Clear" might appears on the display and your receiver might enter Standby mode.
Hope it does.. With your receiver in the Standby mode, hold on STRAIGHT (EFFECT) on the front panel and press STANDBY/ON.
* The ADVANCED sETUP menu appears in the front panel display.ress STRAIGHT (EFFECT) to select the desired setting.
RESET = To reset your receiver to its factory presets.
CANCEL = To cancel without making any changes Press STANDBY/ON to confirm your selection.
* If you selected "RESET", your receiver is reset to its factory presets and switches to Standby mode good luck
shaun
Aug 24, 2009 | Yamaha RX-V1800
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Televison & Video Logo
41 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jonathon summesfield
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
