Question about Thermador CVS30R Kitchen Hood
Thermador downdraft does not stop going up and going down automatically
Downdraft should stop when it reaches its highest point or when it lowers to the counter top but unless the unit is turned off it will continue to go up and down. Would like suggestion on what to replace before taking the unit apart. Blower is also slow to initiate. I need to turn the blower control to the 3rd setting before it will start up and then I can lower the blower speed. Thank you for your help.
  • Anonymous Feb 26, 2008
    have the same problem for sbout 3 Wks, but now the blower does not work also ?????
I had a similar issue with the Thermador CVS30R hood continually going up and down, and also issues with the fan starting.
The issue was found to be a loose control arm off the motor. The arm itself moved outward on the motor shaft which resulted in it missing the switches that control the hood up/down and fan start.
This was a somewhat simple fix. Make sure the hood is in the down position. Unplug the unit from power(important!). Unscrew the screw that connects the drive arm to the drive link. Unscrew the motor/control cover, then unscrew the 4 screws holding the complete motor/control unit on (2 Phillips-head screw on each end of the assembly). Pull the complete motor/control assembly out, be careful of wiring. Once out, push the drive arm on firmly onto the motor assembly and tighten the screw. When doing so make sure the 2 micro switch arms are not caught and are free to switch.
When placing the unit back in, ensure all wiring is clear from being caught and ground is reconnected. Put it all back together and done!
I found this link to be useful for a parts/configuration diagram:http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232629&diagram_id=194441#d194441
Posted on Dec 30, 2011
  • 4102 Answers
SOURCE: Downdraft up and down
Hi do you mean the air is increasing and decreasing on its own
Posted on Feb 22, 2008
  • 13433 Answers
SOURCE: thermador cooknvent downdraft CVS36R
My quess is you would have to replace the switch / button if its not working properly.
Posted on Oct 24, 2008
SOURCE: Filters for the Kenmore Downdraft Blower
I have the manual on this model.  It says it is part#97009786 key#33. and has a phone# of 1-800-366-part(7278) to call to order. Hope this helps. My lift stop working and I am searching for answers on that.
Greg
Posted on Nov 29, 2008
  • 5 Answers
SOURCE: install a Thermador UCV36 cook'n'vent
I have three 90s on my downdraft unit - 90 down from unit into slab, 90 out from slab to outside, then 90 down again. If you are talking a 6" or 8" dia vent it should not make a difference at all.
Posted on Jan 07, 2009
  • 1891 Answers
SOURCE: Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Posted on Dec 07, 2009
Jxb37 won't lower
My unit always goes up. Sometimes it doesn't go down. Then, after some time it goes down. Could it be the capacitor is bad?
Mar 10, 2014 | GE Profile JVB67HWW 36" Telescopic...
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Feb 22, 2008 | Thermador CVS30R Kitchen Hood
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
Downdraft doesn't alway go down and up.
I have the same problem. Seems to be pretty common that the motor that raises the unit goes bad. Ours is 2 1/2 years old and has not seen that much use....that motor should not have failed that soon...and this is a high end product!!! I have been quoted $289 for a replacement motor and $150 for labor!! So, $450 bucks....gads. The unit, new, cost about $900, as I recall.
May 08, 2007 | Thermador UCV36ASS Kitchen Hood
Thermador CVS30R Kitchen Hood Logo
623 people viewed this question
Top Thermador Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
