Question about Bradford White MI40T6FSX 40 gallon LP gas water heater
What should the gas pressure be on pilot?
Pilot will not ignite even though there is 12 inches of water column to the water heater. This is a brand new valve. Old valve was replaced as it leaked propane.
  • Bradford White Master
  • 5,245 Answers
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Bradford White posts service manuals: Both before and after introduction of ICON (Honeywell) gas control valve
http://www.bradfordwhite.com/documentation/residential/gas.asp
Don't forget to clean air intake locate under combustion parts, using instructions in service manual. Or compressed air. Ample air supply will ensure that combustion chamber does not overheat because of slowed venting of hot combustion by-product that will trip the FV system.
And remove heat trap inserts if water pressure has problem or water heater is humming or whistling
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Nov 28, 2012
How do I make the flame of my water heater pilot bigger, it seems to little and goes out every day. I have installed a new thermo coupling but the pilot flame is small. Is there a place to increase th
If the pilot is going out, it may be from lack of combustion air intake. Make sure you have fresh air in the water heater room...one within 18 inches from the ceiling, & one within 18 inches from the floor. The size of the openings is determined by the BTU's of the water heater.
Dec 13, 2014 | Rheem Richmond 40 Gal Natural Gas 12 Year...
Gas will not light
You need to clean the pilot orifice or burner orifice if no pilot.
Feb 03, 2013 | Suburban Gas and Electric Water Heater, 12...
Pilot does not light
If you are not getting any ignition, make sure the pilot line is not kinked. The pilot orifice could also be plugged. It can be pulled and cleaned. If you remove the pilot line from the gas valve then set the valve to pilot and press it in; if you have not gas pressure at that point' you have a gas valve issue. Otherwise if you get pressur the the orifice is clogged.
Jan 26, 2013 | General Electric Water Heaters
Turn on pilot
there should be a flap or removable tray on bottom of boiler, under this you will find a large button, push in and hold press the igniter button a few times until pilot can be viewed through window. continue to hold it in for 12 sec and release slowly checking pilot is still alight. there may even be instructions on flap or tray.
Jan 21, 2012 | Water Heaters
I just replaced my gas valve thermostat on my 6 gallon Atwood water heater model G6A-7 and the pilot lights fine, but as soon as I turn up the gas, the flame almost engulfs the tank. There is even a flame...
There are a couple of things to check....
I am assuming that the gas is LP or Propane....
make sure that the gas valve is for the right gas and not natural gas...
Also, it is possible that the regulator that cuts the pressure from the tanks is bad and that maybe why the original gas valve failed....
If you have the correct gas valve installed, get a gauge and check the pressure of the gas right before the gas valve...it should be somewhere between 8 and 12 inches water column...
If the regulator is not working properly, check that the vent hole in the regulaor is not plugged by a mud wasp nets or something like that...
heatman101
Jul 16, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Gas hot water tank, pilot light
Look inside the water heater when it is heating the water, the flame should be blue. If it has yellow tips on the flame, it needs an adjustment to the air shutter. There is a nut on this air shutter to make this adjustment. This adjusts the air gas mixture. You may first try just simply tapping on the burner lightly to loosen any debris that may have built up and vacuum it out. MAKE SURE YOU TURN OFF THE GAS BEFORE CLEANING THE BURNER!! Also, check for drafts that may be blowing out your pilot light, Furnace register or outside drafts on windy nights. Some water heaters have an automatic shut down if the water heater gets too hot, so don't have it set to its hottest setting. Most water heaters only last about 10 years or so, It could be you are ready for a new one....Joe
Dec 16, 2008 | Water Heaters
Bradford White MI40T6FSX 40 gallon LP gas water heater Logo
171 people viewed this question
Top Bradford White Water Heaters Experts
Gene Haynes
Mack Baxter
David Spradling
David Spradling
Are you a Bradford White Water Heater Expert? Answer questions, earn points and help others
