Question about Kitchen Ranges
Frigidaire es330 gas range f10 code - Kitchen Ranges
  • 506 Answers
SOURCE: we have a f10 error code on our electric range
F10 is thermal runaway. The RTD is most likely bad. Open the oven door and look in the upper corners you will see a little metal rod protruding from the back of the oven, this is the RTD or resistive temperature device. A local parts store should have these.
Posted on Dec 15, 2009
fridgetech
  • 473 Answers
SOURCE: frigidaire Store code
You can find the newist frigidaire codes at this link:
http://www.applianceaid.com/faultcodes3.html
Looks like yours is a bad oven temp. sensor also called RTD.
Posted on Nov 07, 2007
  • 341 Answers
SOURCE: frigidaire gas range ES100 oven will not light
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
Posted on Jul 18, 2009
  • 3239 Answers
SOURCE: kenmore gas range standard sears model displays
hi check out tie tie on fixya they have seen this problem
Posted on Feb 09, 2010
TheMobilian
  • 8220 Answers
SOURCE: I need to replace Frigidaire ES330 Range bottom
Bottom element for FEF366DB
Posted on Mar 15, 2011
F10 fault
F1 through F10 fault codes are runaway temperature codes.
If this error code is shown while the oven is in day time mode, the Electronic Oven Control (EOC) would need to be replaced. Otherwise it may be the oven temperature sensor or Resistance Temperature Detector (RTD sensor).
Sounds like you will need to contact an appliance repair technician in your area to test each to isolate the problem.
Apr 13, 2014 | Frigidaire PLEF398AC Electric Kitchen...
I was trying to on oven all of a sudden massage appear f10
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Mar 29, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
Frigidaire es300 gas range kepps flashing f10 and f13.how to resetand get the clock working
Hello Carol Martin - Typically, error codes F10 and F13 could indicate a variety of issues. The range could possibly have a shorted keypad, runaway temperature (higher than normal temperature), faulty EOC (electronic oven control) or, display wire harness missing/not connected. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Mar 06, 2013 | Frigidaire Gallery GLEFZ384GC Kitchen...
F10 error code on Model # FEFL79GCA Frigidaire Stove
Hello - Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 24, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gas range model ES330 error code SAb
This is SB mode, show room mode. To deactivate showroom mode, remove power and reapply. Press Cancel to bypass programming clock. Within 60 seconds of reapplying power, press Oven Light key and top oven Timer key simultaneously.
Aug 05, 2012 | Kitchen Ranges
Fridgedaire stove fgf337ebd f10 code
Hello
Welcome ,
F10 Runaway Temperature.
(F10 only) Check *RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
You will need a professional diagnoses to determine the extent of this damage
Thank You Huum
Please remember to leave a solved rating before you sign off!
Dec 20, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
