Question about Kenmore Elite 45986 Front Load Washer
Sounds like a slot machine when pumping
When my washer is pumping out water it sounds like a slot machine. I know there must be a lot of money lost in the washer. Now water is flowing from the bottom of the washer like crazy.
  • 640 Answers
Ouch...pull the bottom panel off and clean you pump filter..i get halfsees..onthejob
Posted on Jan 10, 2009
Fisher & Paykel top loader just beeps at the rinse cycle and won't keep going. We had a guy out to repair it. He waited until i wasn't watching, did something, then charged us a lot of money. Now it's...
you did not say if the machine was full of water if so your water pump is probably blocked or failed turn power of to machine lean it back so you can get to the water pump try to spin the pump by rotating the fan on the end of the pump if it releases put washer back in position turn on power advance washer to spin and see if it works let me know how you go
Apr 07, 2011 | Fisher and Paykel Washing Machines
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine
sounds like you have something stuck in your pump. I know it sounds strange that it more than likly does not make any noise in the drain. But i garrenty you there is a problem within your pump. Tilt the unit back and prop against the wall. DO NOT TIP ALL THE WAY OVER! you will see the pump it has 2 clips unclip them take the 2 hoses off and remove the pump. water will come out so be prepaired with towels. look inside the pump there will either be money in there or a bra wire. MAKE SURE YOU TURN THE POWER OFF FIRST. Let me know how it goes
Jan 03, 2009 | Kenmore 22622 Top Load Washer
My kenmore h3t washer is showing codes f and sud
Hi!!! it seems that you have something wrong with your drain pump check your drain pump and make sure something did not get stuck inside also in all front loads some water does remain in the sump area .I know that trust me..pure some vinegar in around a cup and put it in a normal hoe cycle ..Good luck..
Jan 03, 2009 | Kenmore Elite 45986 Front Load Washer
We have a Whirlpool Gold Ultimate Care II Washing Machine. Washer will fill with water, but when it tries to go to another cycle you just hear a loud rumbling noise and the basket will not spin.
Peace jjones16 ,
huuum At your service!
You have a Whirlpool Gold Ultimate Care II Washing Machine. And the washer will fill with water, but when it tries to go to another cycle you just hear a loud rumbling noise and the basket will not spin?
Correct?
So!
Sounds like the coupling connecting the transmission to the agitator is worn out!
If I were there hands on I could be definite.
But it sounds like you need this replaced!
Thank God it's not the transmission.
When a transmission goes out of warranty, it;s not worth putting good money into bad! They are just to expensive a repair!
Only a hands on laundry tech can make the diagnoses.
This time you should call service
Let me know what is the final results.
Please write me back.
How old is the washer??????????????
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You,
huuum
Please give me a good rating before you sign off.
Thank You
Sep 12, 2008 | Whirlpool Washing Machines
WATER STARTED COMING OUT FROM THE FRONT DOOR
Peace aminajmay,
ngafm At your service!
Sounds like the pump is worn out!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Thank You
Sep 09, 2008 | Washing Machines
Washing machine when on drain wont drain the cycle wheel keeps turning looked in the manual this states a fault , have drained the water out of pre chamber/pump . the cover will not rotate it appears to be...
Peace Friend,
Things wear out! So is life!
Sounds like the coupling between the transmission and the agitator is the problem!
I were there hands on i could repair it.
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Bless You ngafm
Hoover washer dryer
Peace aminajmay,
Sounds like there is an electronic problem.
DO NOT RUN THE APPLIANCE tillit is checked out with hands on from a laundry tech!
Bless You ngafm
Thank You
Sep 09, 2008 | Hoover Washing Machines
Kenmore quietpak2 no longer rinse, drain, spin
Sounds like the pump, eighter blocked or needs new pump.Place outlet hose in to bucket to drain, if no water comes out its blocked, if water flows freely possible needs new pump.
Slim jim1
Nov 19, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
