Question about Maytag Refrigerators
Maytag PBF 2255 HEW refrigerator JAZZ board replacement issue
Jazz board was replaced with new OEM part (unit would not defrost, evaporator coil got iced up, internal recirc fan and defrost heater are both good).
Now green LED displays flash double zero's (0 0). Is the new jazz board the wrong one? Old part had sticker on chip inside that reads "JAZZ 09". New board has chip inside with sticker that reads "JAZZ 14".
I'm now into month 2 of this probem--HELP!
  • 1 more comment
  • gotmoldohio Jan 10, 2009
    There were no instructions on programming the board, so no, I didn't do that. Where would I get programming instructions? Only the part arrived with the shipping paper.
    This board is in the inside, top, front of refrig box. You open the top door to refrig and right behind the door light switch are 2 small LED numerals, with up/down arrows for temp control next to/on either side of each LED.(Nothing in the doors on this unit; not french doors, no dispenser, water,etc). To access this electronic control board, you have to get your head inside the frig, then look back toward front, stick a screw driver into two tabs and push them in to drop the plastic housing on the control panel (with the arrows & LEDs mentioned above). In the plastic housing are 2 boards. One has the JAZZ09 chip, and there is a flex circuit connector to another smaller board that has the display LEDs and push buttons for the up/down temp controls.
    Thank you! for your reply, Bill.
  • gotmoldohio Jan 11, 2009
    I read others' posts and found the programming codes under the front bottom of the unit, right above the condenser coil, in a flat plastic envelope. Virtually invisible unless you know it's there and to look for it.
    With the codes, I was able to program the new Jazz14 board. Now we'll see if that was in fact the true problem...
  • Bill Dozier May 11, 2010
    did you program the boards and the jazz board are you talking about the mother board on the rear or the dispenser board on the door every one has different lingo and calls stuff different thing so i just want to clarify so I can tell you the right thing to do let me know ......Bill
    Sergeant:
    Champion:
  • 262 Answers
Thats different I was thinking of something else the board you are talking about just controls the temp. controls this may be your problem call1-800-688-9900 maytag or 1-800-253-1301 whirlpool they can give you a better idea on the part number issue this may be the problem
Posted on Jan 11, 2009
  • Bill Dozier Jan 11, 2009
    I THOUGHT YOU HAD TO PROGRAM THE BOARD BUT IT HAS BEEN ALONG TIME SINCE i HAVE DEALT WITH A JAZZ BOARD AND THEY CHANGE THE NUMBERS SO OFTEN IT''S CRAZY.I HOPE THIS GETS YOU BACK COOLING AGAIN.IT'S ALSO HARD TO DIAGNOSE WITH OUT BEING THERE TO SEE /HEAR/AND PUT A METER ON IT AS ANY ONE WOULD TELL YA GOOD LUCK AND LET ME KNOW HOW IT WORKS
I just asked the service dept, "Are you programming the Jazz bd or the controller?: I had my Jazz bd replaced, worked less than a month. had tech come back out and reprogram, worked less than a week So I put old Jazz bd back in and reprogrammed it. So then I put new Jazz bd in and it came up as though it had been programmed meaning that the controller bd was programmed.
Posted on Jan 04, 2010
Maytag MBF2558HEQ. Evaporator freezes up. I R/R the door seal, the defrost bar, the defrost thermostat, and the thermister (which I realize now I didn,t need to replace). Unit still freezes up. If I do...
If the evaporator is just freezing up around the area where the refrigerant first enters unit, then it may be low freon. When the defrost element is fubar the entire evaporator is covered with ice not just a segment of it.
Sep 19, 2017 | Maytag Refrigerators
Kenmore fridge model 59668049801 bottom freezer not defrosting, does this unit have a defrost timer? where? or is it part of the jazz board?
he defrost timer is the jazz board fail easily after power surge. I would also recomend checking the Bi metal the tops pop off on them frequently
Jun 29, 2011 | Whirlpool EV209NBT (19.6 cu. ft.)
I have a Maytag gz2626gekb side by side and the damper door seems to get stuck due to chips of ice forming around it. It jams on the chips of ice. Ive replaced the damper assy already and still experience...
If your air damper door is constantly getting ice forming on it there is a reson for this. This is most oftern caused by an improperly sealed fresh food compartment door gasket, a warped door or improperly adjusted door hinges. Having said that... there can be other causes such as a clogged compartment drain in eaither compartment that forces air to rapidy transfer from one compartment to the other side when one of the doors is opened and the rapid temperature change initiates the rapid air flow and eventual condensation / freezing.
Make sure your compartment drains are clear and the end of the drain tube that terminates in the catch basin under the unit is free of obstructions. (rear fiberboard compressor cover removal required) To cause the rapid air transfer I spoke of above this tube has to be blocked.
If you discover that the compartment drain is clogged with ice.... the only fix / remedy is to perform a manual defrost by unplugging the unit, removing the freezer contents and directing an exteranl fan into the freezer compartment for just over 2 hours. The reason for the 2 hours is that should there be ice in the drain funnel the water in the top of the funnel accumulates on top of the ice and insualtes the ice in the funnel from melting so you just have to wait until it warms up over time.
After perforning this manual defrost... use a vacuum to first attemot to remove any debris from the drain tube end and then put the hose on exhaust and direct air into the end of the compartment drain tube to float out any debris from the compartment drain funnel.
One question I have is why are you changing Jazz boards? Do you suspect you have an Automatic defrosting problem?
Thanks for choosing FixYa,
Kelly
Mar 26, 2011 | Maytag Refrigerators
Amana French Door fridge not cooling
you have a problem here
you need to get the secondary defrost kit installed
it is not the jazz board
unless he is not programming it right aftwer install
but check your back wall for frost
if you have frost you have an airflow issue
whats happening is the door is being left ajar even a 1/16 gap is an issue
when hot air enters the unit fromn the gap it condenses on the diverter behind the freezer wall
after a few weeks it builds up enought o cause problems
there is a kit you can get that will divert electrical heat to the diverter and keep it warm enough to defrost it there by never having the issue again
Oct 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Maytag PBF2253HEW temp control lights blinking
Your heading has two model #'s if your dealing with a PBF2253HEW you need a new jazz board pn W10165748 this part also controls your automatic defrost cycles if lights are flickering you should replace prior to something else going wrong
Apr 02, 2009 | Amana ARS2464B Side by Side Refrigerator
Maytag PBF 2255 HEW refrigerator Freezes up, won't defrost
To rule out the evap fan.
The evap fan should run all the time except when in the defrost mode.
Dec 27, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
How do I test the defrost thermostat?
the fan is ctrl by the Jazz board the thermdisc is for defrost post your email and I will send you the manual on test process and test point as well as the defrost
Feb 12, 2008 | Amana AFD2535DES French Door Refrigerator
Maytag mbf2258hew replace jazz board
bug, the jazz board is pretty easy to replace. The light cover will slide off toward the back. Now if you look behind the control panel you will see two slots. Take a flat blade screw driver and push the cover tabs in while pulling down on the cover. The cover will come down. Two slats slide in on the front and will release, disconnect the harnesses and install the new board. Reverse the process. Catriver.
Sep 04, 2007 | Amana AFB2534DE Bottom Freezer French Door...
Refrigerators Logo
3,377 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
