Question about Refrigerators
Ice dispenser will not dispense ice, but it will dispense water
We just moved and everything was fine before moving. After re-hooking everything (had to take the doors off), the dispense won't dispense ice.
    New Friend:
  • 22 Answers
It might not be hooked up right. Or there could be something blocking the ice dispenser.
Posted on Nov 28, 2012
fridgetech
  • 473 Answers
SOURCE: How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Posted on Oct 06, 2007
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
SOURCE: ice/water dispenser control panel
@ Scootertramp
You tell us about this board or that board but never tell us where to located or get at these boards. Would you please clarify that?
My ice and water started dispensing sporadically, though the lights were working fine. After I removed the kick board at the bottom, cleaned out the little connector and put it back together, nothing on the door works. All else works fine.
Posted on Sep 08, 2008
SOURCE: Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
SOURCE: GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Posted on Sep 11, 2008
Water dispenser takes a long time to shut off.
Sounds like the water valve needs to be replaced. If you move your cup and it continues to pour out water valve is, leaking through
May 27, 2015 | Scotsman MDT5N40W-1J Touchfree Water...
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
I just hooked up my ge fridge ice maker/water dispenser and none of the lights come on and no water will dispense
Remove It now and Wait for 24 H
cuz u must be moved it and now the compressor gaz -freon- needs to get float.
Jan 22, 2009 | Refrigerators
Water & Ice dispenser quit on Kenmore 106.9535110
recheck the electical connection at upper frz door hindge sometime a wire could be pushed out but check to see that the control lock was not set by accident
Dec 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No light on water and ice dispenser not working
there sure seems to be a lot of problems with this GE refrigerator
I will try to find answers soon.
Jul 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
442 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
