Question about Brother MFC-5440CN All-In-One InkJet Printer
Is there a way to only use black ink cartridge?
I only need to copy/fax in black and white. And don't want to always be replacing the color cartridges. Is there a way to bypass the color cartridges?
  • tzukerman Jan 11, 2009
    Sorry I didn't state problem correctly. I don't have the printer hooked up to my PC. I'm just using as copier and fax. Is there a way to set properties from a printer menu?
    Novelist:
  • 180 Answers
Easily done! Right click your printer and choose Properties. Look for Printing Preferences and then a Color tab. You'll find an option to print in grayscale. Look at the options and you'll find an option for Black ink only. Locations of these may vary slightly but will also give you the option to use less ink also. This will help save on replacement costs as well. While you're in there, tool around and see what other settings are available to you! You'll be surprised at some of the features available.
Let me know how this works. Please rate this accordingly and remember Fixya.com for future questions.
Posted on Jan 10, 2009
  • 15,935 Answers
Http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_5440CN_5840CN_EN_108.PDF
If you go into your pronter properties... start/control panel/printers and faxes....
Right click on the printer in question, and scroll to properties.
There you will see a series of tabs.
Under the GENERAL tab, there is a button to click - PRINTING PREFERENCES.
under the tab PAPER/QUALITY you can choose B/W or color.
Click OK.
VOILA
  • blueextc3221
    blueextc3221 Jan 11, 2009
    you can press BLACK START before copying each document.
    There is no physical or internal override for the color cartridge other than letting it run out and not replacing it I suppose.
    You have a Photo printer/copier/fax all-in-one, and it is designed to print color. Pressing the BLACK START will, however override the color sensors and only print greyscale.
    Hope this is a little more of the answer you were looking for.
    This is directly from the manual link I posted above....
    How to Fax (B&W and Color)
    Color fax transmission
    Your MFC can send a color fax to machines that support this feature.
    However, color faxes cannot be stored in the memory. When you
    send a color fax, the MFC will send it in real time (even if Real Time
    TX is set to Off).
    Faxing from the ADF
    Put the document face up in the ADF. To cancel, press Stop/Exit.
    If it is not illuminated in green, press (Fax).
    Load your document.
    Dial the fax number.
    Press Black Start or Color Start. The MFC starts scanning
    the first page.
    Delayed fax and Polling Transmit features are not available in
    color.
    If the memory is full and you are faxing a single page, it will be
    sent in real time.
Why do copies in color have multicolored streaks while black & white are fine?
There is a good chance that your color ink cartridge needs replacement. You can tray wetting a paper towel and putting in the microwave for 5 to 10 seconds then placing the cartridge on it for a few minutes. This sometimes will correct that type of problem...Be careful the paper towel will be hot (handle with care).
Aug 04, 2014 | HP Officejet Pro 8600
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
My cannon mp258 cannot print, message show that ink to slow,and the ink indicator appear the Colored ink is almost empty .and also i try to photo copy black and white document but i cannot photo copy even...
Yes. You cannot use the printer even in black and white, until the color cartridge is replaced. They are designed to check the levels of the both black and color cartridges.
Oct 18, 2017 | Computers & Internet
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
I don't use the color printing yet the color cartridges are empty
It's all a scam. I have the same problem and I called Brother and they told me that the machine uses color ink to clean itself. It costs more to replace these color cartridges then to buy a new one, which is what I'm going to do. Buy a black and white from a different company. It's all a scam to get you to spend money on their color ink that you don't use.
Mar 25, 2009 | Brother IntelliFax 1860C Plain Paper...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
Unit Waste Lots of Ink
I have had the same problem, so I decided to use the fax only for sending faces. I took the ink out of the machine so
Aug 12, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother MFC-5440CN All-In-One InkJet Printer Logo
139 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
