Question about Hitachi 31CX6B * 31" TV
Hitachi 31cx6b During the hockey playoffs the tv shut off.So i tuened the tv back on the set clicked but no screen i did turn it manually also same result ,their is like a hum high pitch hum with the set on after clicking it on?
  • 203 Answers
Sounds like a power supply issue.
Posted on Jun 08, 2007
What this activity ends in May or June
NBA (National Basketball Association) playoffs
and NHL (National Hockey League) playoffs
used to end in May or June. Now, they end in June.
Other sports (British soccer and Australian Rules Football) also have their Championship games around the same time.
May 19, 2014 | Games
I simply want to adjust the picture - move it up
it is bit tedious to remove the case and adjust-. if you are very much famliar with opening the case and want to try adjusting it ,only then open it or else dont open as adjusting may effect reverse too- by putting up more image in the bottom to drop and making it more worse.its advisable to get it done by manual technician if very necessary.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Jun 27, 2009 | Hitachi 31CX6B * 31" TV
I have had a Hitachi 42" Plasma screen TV for almost 3 years and recently it has had problems. When you turn it on, the TV only stays on for about 10 minutes, and then the screen goes black with the...
The signal from the STU to the Hitachi box is going in the wrong direction.
Is the adaptor that you have switchable? If so, flick the switch in the
other direction and this will fix it. If the adaptor is not switchable get
one that is. Then set the STU output to RGB.
Hope this Helps. -CA
Jul 14, 2008 | Televison & Video
Hitachi 51S700 won't turn off
Some kind of a problem likely in the magic focus area--is the set showing a error on screen if you engage the magic focus?
One thing not to do is disconnect the sensors inside the screen as that could make things worse......
Dec 02, 2012 | Hitachi 51S700 51" Rear Projection...
6 weeks ago I bought a Playstaion 3 and have been playing 2K9 hockey till the playoffs which I saved the data Season 1. Two days ago when I inserted the hockey game disk the psn3 came on and the icons...
I suggest you sending back since it is still underwarranty...the hard drive sounds like it has gone out as it has on mine in the past. My warranty was up so they wanted to extort $150 and I refused. I fixed it myself for 100 and turned it from a 20 gig to a 320 gig...yaaaaa budddy!
Feb 05, 2010 | Sony Playstation 3 (PS3) Console
My hitachi 57f500 turns itself off after 3 hours of use. Turning it back on restores the picture,
Hi I am Vortash
There may be actually nothing wrong with your set ? .......
This set has an anti surge protection circuit and it is designed to shut down should the incoming power peak above 240 volts or more , is this happenig at random times or around the same time in the evening or day it may be that this safety device is protecting the set .. sometimes local area transformers peak at the time of most consumer requirements this may just coincide to when you sit down to watch tv .. however if it has a habit of doing it at different times during the day .. then this safety circuit may be at fault and require an engineer to service the tv and check for poor components that have changed value .. It explains this is in the manual if you do not have one for your set you can download one for free from http://www.safemanuals.com hope this is of help regards Vortash
May 20, 2009 | Hitachi 57F500 57" Rear Projection...
Trouble regaining tv picture
It sounds as though the TV [video monitor {Hitachi}] is not set to an input that is sending a signal. Snow is the result.
Cycle through the inputs on the set with ALL devices ready to send signal.
If you have good access to the input area you should see all of the names and what is plugged into each.
Jul 27, 2008 | Televison & Video
Video settings reset everytime I turn off TV
Hit the menu button on the remote. Click on Setup. Then click on Set The Quick Start Options. Make sure it is on. That should solve your problem.
Jan 15, 2008 | Hitachi P42H401 42 in. Plasma HDTV
No power on tv
only thing i can say is open it up and check the fuse.
Nov 24, 2007 | Hitachi 55VS69 55" Projection HDTV
Televison & Video Logo
77 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
