Question about Bernina Bernette Deco 600
Presser foot lever fell off
My presser foot lever fell off my bernina 801 sport. i have the screw but can't see where to screw it back in.
    Problem Solver:
  • 6 Answers
You'll need a 2.5 mm hex key metric (you can buy a complete set in Radio Shack for about $10 if you don't have metric). AND you will need to cut down the shorter end of that key about half way (total remaining end will be around 8 mm), as there isn't room for the whole key in that tiny space.
Open the light bulb door, it should be easy to see where it goes but you may need two pairs of hands.
If you take it into a Bernina dealer, they should do it for free as it takes like one minute! Hey...you can ask for nothing! Those guys have all the right tools but there's no mystery, so don't listen to any nonsense.
Posted on Jan 24, 2009
The will on the right of industrial Bernina 850 that moves the food appand down one more what can be wrong
Try tightening the nut in the right side handwheel. It is approximately 1.5 inches in diameter. Tighten it up and the needle should then move up and down.
The presser foot is operated by a lever directly behind it. Move the lever down and the presser foot will do likewise.
Dec 29, 2017 | Bernina Sewing Machines
Presser foot lever fell off . How to fix it
Most likely a piece has fallen off that held the lever in place. You should probably take it to a Bernina service repair.
Apr 21, 2016 | Bernina Sewing Machines
Presser foot shaft twisted
You can correct this.
Put an ordinary foot on. There's a clamping screw at the back of the part that has twisted round. The head of the screw faces towards the right of the machine (towards the hand wheel). Get a decent screwdriver and loosen the clamping screw a little. Turn the part round so that the sides of the feet are precisely parallel to the slots in the needle plate. Retighten the clamping screw.
Try not to let the misaligned part slide up or down which it will if you slacken the clamping screw too much. It's at the right height when the little lever you use to hold the foot in place has engaged about one third to one half it's length on the lump on the side of the foot at the top.
Apr 04, 2014 | Bernina Sewing Machines
Bernina 801 tension problems
When you thread the top thread, be sure to ALWAYS RAISE the presser foot so the thread will seat completely in the tension unit. Your machine is an older metal mechanical machine which makes it last a lot longer than the newer plastic computerized models. However, parts do wear, so perhaps the tension unit has become worn and loose over time and use. If you find you have find you are using a consistently high tension, you may need to have your machine serviced. In addition, slightly increasing the bobbin tension may help balance out the top tension.
Oct 15, 2012 | Bernina Sewing Machines
I have a Bernina Bernette serger 004D/004 and the presser foot has fallen off the machine can I fix this myself?
The presser foot is a 2 piece thing, remove the foot, then remove the top bit that the foot attaches to (the shank). Look at the bottom of the shank while pressing the little lever or button on the back of it, you will see how the foot attaches to the shank.
Oct 18, 2011 | Bernina Bernette 75
My Bernina sport 801 is making a loud screeching noise heard under the presser foot/bobbin area
clean under the needle plate
clean the bobbin area for loose threads or lint
if this doesn't make the noise stop then it may need to be serviced
Aug 03, 2011 | Sewing Machines
I have a bernina sport 801 and the fabri feeder
There is a small knob on the lower part of the main body under the stitch length lever. This controls the feed dog up or down. Make sure that it turns easily and fully to both positions. If it does and your problem persists, the feed dog height adjusting point is probably loose. A knowledgeable repair person needs to look at it. It is not a difficult repair, but several approaches need to be taken.
Jan 09, 2010 | Sewing Machines
Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Jan 02, 2009 | New Home Sewing Machines
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
298 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
