The fridge in our office lunchroom has been working well.. however, every month when i go to clean it out, there is a pretty large amount of water under the bottom foods drawer. I've messed with the temperature settings, the only result being the puddle of water was frozen when I turned the temp way up.
I'm not completely sure of the model.. it is a Kenmore side by side with ice maker/water dispenser.. it says "frostless 25" on the door. It is also VERY full most of the time, and the seals around the door look a little worn.
Thanks!
Comments:
Jun 11, 2007
- It turns out, there was a crack in the cold water reseviour tank inside the fridge. It is where water is stored to cool before it comes out the faucet on the door. I am going to try to disable the water supply to that, without cutting off the water to the ice maker. If anyone has any tips on how to do that, it would be much appreciated. Thanks
pull the ref out. remove panel at the bottom on the back of the ref. the water valve has two solenoids on it. one for the i.m. and one for the cold water. unplug one solenoid. does the water dispenser still work? yes: you've unplugged the wrong one no: you're good to go.
check if there is a drain hole in middle of gulley at back of fridge. this is probably blocked. push something flexible down hole and check water drains freely by pouring a small jug of water in gully
Was this helpful?
Yes
No
Popular Solutions for Kenmore 51262 / 51264 / 51269
Kenmore 51262 / 51264 / 51269 Side by Side Refrigerator
WR55X10415 GE Side by Side. None of the lights on my dispenser panel are on and the unit does not...
(More)(More)
WR55X10415 GE Side by Side. None of the lights on my dispenser panel are on and the unit does not dispense ice or water. I understand I might need a new WR 55X10415 control panel ($120.26 from GE includes shipping to Hawaii). My question is...can I remove my old control panel from the front....I tried and it seems like it's glued..it will not snap out.
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
The fan is blowing and the freezer is staying frozen, but the regrigerator isn't as cold as it...
(More)(More)
The fan is blowing and the freezer is staying frozen, but the regrigerator isn't as cold as it should be. We have adjusted the temperature control, but it doesn't get any colder. It stay a little under room temperature. I 14am unable to locate the model number, but here are some numbers I found on the back DA73c12RBU6,AB298159,AVH87747
Posted. Thank You!
ge gss25qgmc-ww refrigerator is runnig, but not cool or freez. when i unplus power for 30 min to an...
(More)(More)
GE GSS25QGMC-WW refrigerator is runnig, but not cool or freez. When I unplus power for 30 min to an hour and plus power back on. The compressor is runnig, cooling about 12 hours. After that I hear the fan running, but compressor is not working.
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
