Question about Garden
Kawasaki fj18ov engine won't start
Gets fuel , has spark, valves look like they are operating but it does send vapors out carb intake and exhaust at same time,? bad head gasket maybe?
  • 65 Answers
SOURCE: fb460v kawasaki will not start
check your camshaft to see if exhaust loab has been worn off. have seen this before
Posted on May 02, 2009
panilling9
  • 284 Answers
SOURCE: 4.5hp Sears/Tecumseh motor starts and dies in 5 - 10 seconds.
metal or plasic float?
Posted on Jun 21, 2009
  • 57 Answers
SOURCE: Engine won't run unless the choke is on - Deere 14SB Push Mower
It's starving for fuel. When you push the throttle all the way forward it closes the choke. You took it apart but you probably didn;t get all the junk out of it. Easy fix is to put some SeaFoam into the tank and run it. This cleans all deposits and debris from the jets. I have used this stuff and put it in the tank and start the engine and sit back and let it run. After about 5 minutes the engine will smooth out and run fine.
Posted on Jul 30, 2009
  • 10865 Answers
SOURCE: Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Posted on Sep 14, 2009
  • 582 Answers
SOURCE: Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Posted on Sep 17, 2009
Testimonial: "I think you're right about the puller for the flywheel. Thanks for the input."
1987 Kawasaki GPZ 1000 RXv will not rev past 3000 RPM
Hi, Mick and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor damaged, contaminated, sticky float, plugged jets.
13. Multiple carburetors out of sync.
14. Fuel filter clogged.
15. Old or contaminated fuel.
16. Fuel tank vent system plugged or carb vent line closed off.
17. Gas cap diaphragm valve faulty.
18. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
19. Carburetor controls misadjusted.
20. Incorrect valve timing.
21. Valve springs floating, weak, or broken.
22. Damaged intake or exhaust valve.
23. Incompatible performance parts.
24. Control module may be in "LIMP" mode
25. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
wont go over 3000rpm
HELP 08 1k won rev past 3000 rpm
Kawasaki GPZ900R ZX900 Workshop Service Repair Manual 1984 1990 1 Download... $17
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Jun 08, 2017 | 1987 kawasaki GPz 1000 RX
My kawasaki z1000 2003 does not want to rev starts and idels beautifully but when i get to about 4000rpm it doesnt pick up revs ... can anyone give me some advice on what i can look for.
Hi, Wessel and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition and leaking check for spark leakage in the dark.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intermittent short circuit due to damaged wire insulation.
8. Intake air leak.
9. Water, dirt, or rust in the fuel system, fuel pump and/or filter.
10. Old dead or bad fuel.
11. Faulty fuel pressure regulator
12. Pinholes in the in tank plastic convoluted tubing from the pressure regulator to the quick disconnect check valve.
13. Fuel tank vent system plugged.
14. Throttle body controls misadjusted.
15. Damaged throttle body or intake seals.
16. Loose, dirty, or corroded ignition module connector at crankcase.
17. Faulty MAP, CKP, O2, and/or CMP sensors.
18. Incorrect valve timing.
19. Weak or broken valve springs.
20. Damaged intake or exhaust valve.
21. Check for engine trouble codes.
22. Clogged air filter.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
03 Z1000 won rev beyond 5k rpm
https://zzrbikes.com/threads/60968-HELP!!-ZZR1200-wont-rev-over-3000-rpm
Kawasaki Z1000 Service Manual
Kawasaki Z1000 ABS Owner Manual
Oct 27, 2016 | 2003 kawasaki Z 1000
Massey ferguson 65
having to use the choke indicates a problem in the induction system
possible blocked main jet in the carby, inlet gasket leak, loose carby, fuel line blockage , dirty fuel , blocked air filter
because it runs , the distributor is the last thing to check or it would not be sparking at the plugs
Aug 22, 2017 | Cars & Trucks
Yamaha jog r 50cc won't start first thing in the.morning put new choke on still no good
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
1995 yamaha jog wont start plz help
Yamaha Zuma won start
https://scootergrisen.dk/scooterhjemmeside/download/yamaha_jog_servicemanual.pdf
OEM parts for Yamaha
YAMAHA JOGR JOGRR CS50 Owner Manual
Mar 16, 2013 | 2006 Yamaha Jog R
Murray 10/30 riding mower has spark but not firing, with a puffing sound out the air filter when trying to start it.
Gavin, the symptoms indicate that the intake valve is stuck open, it could be that the exhaust is also stuck, but normally when an engine sets up, only one stem corrodes and gets stuck. It matters little though which one is stuck, you will still need to have a valve job.
junkl
Feb 26, 2013 | Murray Garden
Missing at low rpm's
Hi, Ray and the usual suspects are:
Vulcan Sputtering at Takoff Low RPM
http://www.vulcanforums.com/forums/sitemap/f-56-p-11.html
KAWASAKI VN800 Service Manual
http://mybikemanuals.com/kawasaki/kawasaki-vulcan-owners-manuals
May 14, 2017 | 2003 kawasaki VN 800 Vulcan Drifter
My echo pb-2601 leafblower wont start
if you have spark then you have a fuel delivery problem or exhaust clogged
Nov 12, 2011 | Garden
1998 Craftsman riding mower, 16 horse Kohler engine, engine starts won't stay running, won't run more than 10 seconds. Appears to have good spark, checked fuel filter and supply is good. Adding gas...
The exhaust valve opening at the beginning of the compression stroke is designed to make the engine easy to crank.
Since you know the exh. valve is opening, it means you have torn into the engine (maybe ?) because you don't really see it any other way. Did you put it back together correctly ?
IF an engine has spark, proper timing, compression and fuel it will run.
Since yours runs for a bit, I say you have a carb/fuel delivery problem.
Dec 07, 2017 | Craftsman Garden
Fb460v kawasaki will not start
May 01, 2009 | kawasaki Full Suspension Mountain Bike Men
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
